Rotary Carving Tools *LINK*
Brad Vietje
>This is a question about larger rotary tools. I have seen a number of sources for the Lancelot -- essentially a small, circular chain saw -- but I am looking for a good source for the Arbortec (sp?), or one like it. I have a friend with both styles, who says the chain saw tools are more aggressive and grabby than the 3-tooth Arbortec-style cutters. He feels the 3-tooth cutter is much easier to control and feels much safer. It looks like Arbortec also makes a multi-tooth hard disk cutter, but that looks more like the chain saw blade...
I'm mostly looking to texture the outside of bowls, so a small tool for tight radius work isn't needed.
Can someone here give both opinions on these larger carving tools, as well as good sources for them? Thank you kindly in advance.
Safe spinning,
Brad Vietje
Newbury, VT
Arbortec Wood Carving Tools
