Spalted live oak and wenge box....
Mike Stafford
>Jamie Donaldson sent me a nice big stick of very spalted live oak a while back and I had to decide what I was going to do to use it. I finally decided to use several gallons of CA and sanding sealer to consolidate the wood. I rough turned the blank and soaked the wood with sanding sealer and/or CA and repeated the process as I turned closer and closer to finished dimensions.
I found it difficult to cut a decent flange on the body of the box and turning the lid thin was almost impossible as it became very chippy. I decided to use something contrasting thus the wenge. It is a piston fit lid and is snug enough to stay in place if you lift the box by the lid yet not overly difficult to remove.
The box is 2 1/2" tall and 3 3/4" in diameter. I would appreciate your thoughts on replacing the lid with another wood such as blackwood. Maybe you have some other wood suggestions.
Inspiration for this form was taken from Matthew Hill's wonderful boxes which I admire greatly. He probably makes the most beautiful boxes out there.
All comments appreciated...
