Question on pneumatics
Roger in MO
Roger in MO
>I'm using a "cheapo" die grinder for power sanding. The throttle is very sensitive. If I'm very careful and start the pad on the turning, sometimes I can sand very well. At other times the speed gets away and the sanding pad separates and goes into orbit!
I'm wondering if adding a valve, such as a ball valve, just ahead of the tool, would allow me to control the maximum speed. The tool throttle would control the speed up to the maximum allowed by the valve.
Would this work? Or is there a better way? Or should I go back to an electric drill?
Thanks
Roger in MO
Re: Question on pneumatics
Dick Coers
>You can limit the air flow, but I'm pretty sure you will also kill the torque. I have only used a DA sander (5" pad) for automotive work. They had a built in valve, and if you cut the air too far, I could stop it without much force. You might be able to reach a medium point though. Stop by Harbor Frieght and you won't have a big investment in the experiment.
You might also switch to a positive locking system for the discs. Something with a twist lock will prevent the satellites.
Tony Reynolds
Tony Reynolds
>I've had good luck using the pneumatic drills sold at Lowes. They are Kobalt brand, come in regular and right angle forms, and have good speed control.
DavidWalser
>Roger,
Depending on how the trigger on your die grinder is designed, you might be able to install a bumper beneath the trigger to limit it's travel. With a pneumatic palm sander, I used to limit the paddle/trigger's travel with some wadded up paper towel. I'd think something similar should work for your die grinder -- perhaps a wad of paper secured with a rubber band.
Re: Many die grinders have a slotted screw in the
Al Crandall
>side of the grinder body. Adjusting this screw limits the maximum rpm of the tool.
Roger in MO
Re: Question on pneumatics Thanks
Roger in MO
>Thanks for the responses. I tried the folded towel and it worked but seemed awkward. I placed a small ball valve just ahead of the grinder and that seems to work very well. I can adjust the valve as the grinder is operating. I'll check if this unit has the slotted screw adjustment. If it does won't my face be red! Thanks folks.
Roger in MO
Texian
>Consider use of VSR electric drill. Why run a big compressor when a 1/4 hp electric drill will do the job?
