utensils and a bit of back-patting
ktkjr
>After a year of turning wood, and a (kind of) frivolous decision to try and make money doing it, I made a sale! (Actually I sold a christmas ornament last year, but this is way more significant.) 40 kitchen utensils to a shop called Kitchen Window; spurtles, spatulas, and honey dippers.
The horse is out of the barn, but I've got a question. What would be a good finish for kitchen utensils? I used mineral oil, and on the label I stated it should be reapplied as needed. My reasoning was that it's cheap, readily available, and benign.
Re: utensils and a bit of back-patting
utensil pic NM
ktkjr
utensil pic 2
ktkjr
Scott Hurley in N VA
>I suggest walnut oil - Mike Mahoney's or just plain walnut oil from the grocery store.
Scott
Steven Antonucci
If you can afford it...
Steve antonucci
>I would recommend getting a big pot of mineral oil and warming it (CAREFULLY!). Might even do the same with the wood (200 degree oven) and soaking it for a little while to absorb a bunch more than just a quick wipe.
Then, mix a little bit of beeswax into some of the oil as a top coat. Smells nice, looks good...
steve
ktkjr
>I haven't much (no) expeience with finishes. That said, I was under the impression that walnut oil ain't cheap and ain't ready got. I think the jury is still out on whether it's benign.
Re: If you can afford it...
ktkjr
>I think I see it. A big cast iron pot in the oven, filled with (very hot) mineral oil.
Whwn do I add the beeswax?
Brad Vietje
Re: Walnut Oil -- Allergies??
Brad Vietje
>Scott,
Are there any allergic reactions when using Walnut Oil finishes?
I'd still recommend Tried & True Original -- see post below about safety issues for the link. One quart can will do hundreds of utensils easily, and the user can just apply a little mineral oil whenever they look "dry".
Safe spinning,
Brad Vietje
Newbury, VT
Re: Walnut Oil -- Allergies?? COULD BE *LINK*
Russ Fairfield
>The boogie man in the oils are the proteins, and that depends on how the oil was extracted. Distillation and most hot processing removes the proteins. Cold pressing does not. Unless the oil is labeled, there is no way to know the difference.
The following explains it all -
Allergies To Oils
>I gently warm the mineral oil. I start shaving wax into the mineral oil. When the wax shavings start melting, it is warm enough. I usually add enough to make a "gel" and then warm it more till is liquid and then pour it into jars.
You don't need much - just a small saucepan. If you want to try some different things, you can vary the waxes. If I want a harder finish, I add some carnuba wax. Beeswax is soft and will give you a soft sheen. I usually buff it in while the piece is on the lathe. It works well for rolling pins, spurtles and honey dippers.
80% beeswax, 20% mineral oil
david
>Eli Avisera just left for California after demonstrating his considerable turning skills and enjoying what he said was the most beautiful place he has ever visited. He applies this wax/oil to all his pieces before sanding to raise the grain and cut down on the dust produced.
Not So,
Jorge Castaneda~Downeast Maine
>ktkjr,
I sell many dozens of bowls and platters a year, most of those pieces are finished either with hazelnut or walnut oil, bought from the local health food store, sold for use in salads. The walnut is kind of like friction polish and a small amount goes a long way. Both darken the wood a bit. Although I have not used it I understand sunflower oil is another good oil and darkens the wood less.
Give them a try.
Jorge
Be Careful - - - -
Pete in Holland, MI
>A container of hot oil that you are putting things in? Ever seen what happens to a propane fired turkey deep fryer when a big bird is dropped in?
Suggest warm the oil, then take it off & away from the heat source while dipping to reduce any chance of fire.
Greg Haugen
>Bill Luce, bowl and vessel turner, told me about Tried and True finishes so I tried it. The response I've gotten from customers has been excellent. The "original" danish oil is polymerized linseed oil and is food safe in liquid form or dry. There are no thinners in it so "THIN COATS" are the key to timely drying times. I like the finish a lot and it is my first choice.
A few years ago our club had the honor of hosting Russ Fairfield for a weekend and it was excellent!! Highly recommend to every club!! He talked about the Walnut oil issues and how it all depends about how it's made. He did mention, at that time, there was one "grocery store" brand that would be safe and would dry but I can't recall which one. When in doubt, buy "walnut oil" that is sold for finishing; Mahoney's, Lee valley's, and there is another place that Dale Larson, Bowl turner from Oregon, uses to buy larger quantities in 5 gallon buckets.
The ole' Mineral Oil and Beeswax is a good choice as well. I used to make it in a "double boiler" to help to control the heat.
My first choice, and what I use everyday is Tried and True's Finish.
Duly noted.Thanks
ktkjr
