Which Waterlox?
Steve Kubien
>Hey there,
I want to pick up a can of Waterlox and try it since I've heard so many great things about it. Which version are most turners using? Semi-gloss in the red can?
Thanks,
Steve
Which Waterlox?
Steve Kubien
>Hey there,
Thanks,
Steve
I use this one *LINK*
Dave Peebles Lyons, Ohio!
>Hi Steve,
I use what is called Waterlox Original. Sealer/Finish
Here is a link to a picture of the can.
Best wishes,
Re: Which Waterlox?
Roger
>Check out Russ's Corner. A great article under Finishes, with a section on Wipe On's including Waterlox.
Gloss or semi-gloss?
david
Thanks everyone.
Steve Kubien
Re: Gloss or semi-gloss?
>Hi David,
They call it a medium gloss. But I find in use I can get anywhere from a semi gloss to a really shiny finish depending on the number of coats I use.
This piece had 6 coats of finish 24 hrs apart. I then Buffed it (Beall) after waiting 30 days.
It has the type of finish on it I was looking for... I think. :)
Best wishes,
Dave
Ditto
Carole Valentine
>You can get matte to gloss depending on how you use it.
