A55 Smoothing Plane
Cast iron legs or build a new stand?
Michael Bush
>Twenty years ago I built a lathe stand. It is big, heavy, and sturdy, or was. It has a pretty big beam across between the legs full of sand. The thing is, it's really showing its age. I've upgraded lathes a couple of times, but have mounted them on this stand, and the top is becoming pretty seriously worn, among other things. It's less and less sturdy, but it still absorbs almost all vibration.
With one of the lathe upgrades at one point I got an older Rockwell-Delta stand, which I have never used.
I really want to avoid rebuilding the homemade stand, but only if the cast iron legs are likely to be a satisfactory alternative. How much am I going to miss the sand? Can anyone comment on the vibration absorption of the cast iron legs?
Re: Cast iron legs or build a new stand?
GalenV in Iowa
>How much work is it going to take to adapt the Rockweel-Delta stand to your current lathe?
If you have to do much modification then I'd build a new stand that fits your needs.
If your old stand was so heavy, did you ever move it in the 20 years? If you have not moved it much then anchor the cast iron if it fits or anchor a new stand so weight is not that much of an issue or trial and error to weight it.
As a general rule cast iron will dampen or be more quiet than steel or wood as I recall the Machinery Handbook and the equipment we built.
Galen
Steven Antonucci
Both
steve antonucci
>I have cast iron legs and I have a box between them filled with ballast. The legs are great, but the ballast really adds mass. The combo of stiffness and mass is what you want.
steve
Mike Brazeau
>I have one of those old R-D stands and Homecraft lathe sitting idle right now. I always liked the stand and can't seem to muster the will to get rid of my first lathe. I had four two foot curbstones, each weighing about 60 pounds stacked on the lower shelf and it worked well to settle things down, at least for a lathe that had an 11" swing. I did find however that the overall height was a bit low and had mounted the feet on a couple of layers of 2x4.
Robin Corell in Atascadero CA
>I have and use an old delta lathe with the cast iron legs and two 2x8's. set up with just the legs and two pices of wood it can have excessive vibration. A 2' board screwed verticly between the upper and lower 2x8 adds enough sheer to make the stand acceptable. I now have the lathe bolted to the concrete floor and it runs smooth even when turning off center.
Robin
