Black walnut turning help
GalenV in Iowa
>I was given two short logs of a black walnut tree and have never turned green walnut. I do remember some negative comments about turning. More on staining your skin and reactions some have to it. Also trying to finish with open pours.
If you turn a bowl with the bark to the tenon do you need to turn through all the white sapwood or can you leave some of it as a contrast with the dark old wood? Seems like a wide ring of white wood to waste.
For my first time would you rough turn and leave it to dry or turn it to a thin section and let mother nature re-shape it?
Any suggestions?
Thanks
Galen
Re: Black walnut turning help
Keith Tompkins
Keith Tompkins
>Hi Galen,
I think the biggest problem people have with walnut is torn grain, especially in bowl orientation. Tool presentation is the key to clean cuts; using a gouge head-on will tear the surface, presenting the gouge at a shearing angle will cut through fibers cleanly. If you can orientate the blank carefully, the contrast between sapwood and heartwood can be striking. Walnut is still one of my favorites. I turn lots of green walnut, mostly to finished dimensions, but it dries very well.
GalenV in Iowa
>Keith:
Thanks for your comments.
If I use the Thompson bowl gouge I purchased it will "guarantee" I get a good clean cut from start to finish, Right? :>)
Thought that should be programed into each tool but I think there is an error in my lathe tools. Probably the brain behind them. Enjoying turning anyway.
Enjoyed your beautiful holly linenfold piece you posted about a month ago. That's when a turning becomes art.
Galen
John Veerkamp, Western Mo
>Galen,
I also turn lots of walnut. When the opportunity presents i do like to leave white wood for contrast. As Keith suggested, sharp tools are your friends. For a finish I use Mahoney's utiliarian wualnut oil, followed by Renaissance wax. It leaves a lovely "hand" Defects like bark incursions and natural fissures also can produce wonderful finished pieces. I never turn down walnut.. It will crack if you don't seal the ends promptly.
John
Chuck Jones - West TN
>I'd say everything that's been said so far is good advice. I have not been turning all that long, but I've probably turned more black walnut than any other wood. Personally I'd rather rough turn it and let it dry for several months (now that I have developed the patience to do that). But I've also turned some small bowls green to finish and had pretty good results. Never met a piece of black walnut I didn't like. Last couple bowls had some checks which I carved out a little with a carving parting tool and filled with brass shavings from my local hardware store's key machine and/or coffee grounds.
robo hippy
>I like walnut as well, black, English (Persian), and white (butternut). There is one problem with selling black walnut bowls. It is a very strongly scented wood (much less so in english and butternut). Some people love the smell, and it drives others nuts. I don't think I would want to eat ice cream out of one, but salads would be great. The smell does fade eventually, but it takes a long time, and hot soup in one will bring it back. The acids in it will stain your hands and any metal except stainless. For the stain on your skin, concentrated lemon juice will cut some of it, at least better than soap. It is open grained, and I do use more wax on it than on most other woods. It is a fairly easy wood to dry. I prefer the warped bowls. Turn to final thickness, put a couple of wraps of newspaper on the outside, secure it to the rim with tape or several wraps or the plastic stretch film you wrap aroung boxes on a pallet. Cut out the paper on the inside. Some people are allergic to the wood. If I am turning a lot of it in a day, I will wear a dust mask even while turning green wood. I get kind of head achy by the end of the day. No skin irritation though.
robo hippy
Pete in Holland, MI
>Galen -
Have turned all the walnut that I could get. Pretty stuff. I like to leave some of the sap wood on it, as when the rings are laid open in a bowl, there are several transitional colors of grays between the sap & heart wood. All of my bowls are turned green, coated with Anchorseal for at least 6 months, then re-turned.
Yup - - the stuff stains your hands pretty badly. Lemon juice takes it right off though (learned that on this site). Tried Boraxo, mineral spirits, lacquer thinner, and other solvents I had on hand, but the lemon juice pretty much instantly does the trick.
Good luck !
Pete
Brad Vietje
Brad Vietje
>Galen,
The quicker you turn it, the whiter the sapwood will be. Turning green to finished dimensions usually results in whiter sapwood than roughing, drying, and re-turning later (light sapwood can turn grey).
Also, consider making the sapwood a real feature by turning a natural-edge bowl -- very striking. The bark can be very thick, and very corky, so you will need a lot of care to retain all the bark, but the effort is worth it. Even if you strip off the bark, and use the cambium as the "live edge", the contrast is impressive, and can be really pretty.
Safe spinning,
Brad Vietje,
Newbury, VT
