Best type of fasteners for faceplate?
david
>Yes, we are talking about screws here. Getting tired of having to dig out screw threads where the heads are sheared off. Perhaps it doesn't help that I use an impact driver to fasten the faceplate to a turning blank. I also do not pre-drill except on notoriously hard woods. Have tried sheet metal screws and deck screws, but from the local Ace Hardware the shank size available is not very thick. The break-off point is usually just below the head. If I have trouble driving in the screw, I know that pre-drilling is warranted; but the break usually occurs when trying to remove the screws. The only way I have been able to remove the headless screw is to dig around the shaft to minimize the amount of thread in the wood and be able to get a vise-grip plier on it. See in the McFeeley's catalog where I can get some #12 and #14. What do you use and/or recommend?
Re: Best type of fasteners for faceplate?
Steven Kubien
>#12 or #14 are recommended by one of the biggest proponents of faceplate use, Lyle Jamieson. Since my time with him in February of 2008, that is all I have used and never had a break-off. Lyle also loves his impact driver so I doubt that is your problem.
Good luck,
Steve Kubien
P.S. I recently saw in one of the catalogues that someone is offereing a drill bit specifically to drill/grind/mulch headless screws. This is not your typicaly extraction bit. More of an extinction bit! Sorry I can't remember where I saw it but if I do, I post it.
Ray Binnicker
>I've used the screws designed to be used with the "Kreg" pocket joint jig. I've had good luck with them, so far.
Ray Binnicker
The biggest, fatest
Jorge Castaneda~Downeast Maine
>screw you can fit in, at least a #12 steel wood screw, note that real wood screws, have a smooth shaft between the flat head and the threads, if it has threads all the way to the head is a sheet metal screw, guaranteed to loose its head. I my local hardware, the steel screws are made out of pot metal, read poop, so I go for the stainless steel ones.
You may have to pre drill, I use a tapered drill bit.
$0.02
Jorge
David Walser
>I found some #12 hex head sheet metal screws at the local borg for use with my faceplates. (I had been looking for square drive screws but could not find any at the borg.) The work well and, so far, I've not broken one off. But, then, I always pre-drill.
pocket screws...me too
Thad
Roger Dunn
Roger Dunn
>I use #14 sheet metal screw either countersunk or pan head depending on the faceplate holes. Remember the old Norm trick to wax or oil the screws before you drive them - hence - no snap offs. But pre-drilling with tapered bits works without wax and oil.
steve worcester
>If they will fit your faceplate, the best I have found are Simpson Strong Drive woodscrews (1/4"x1.5"). They are made for attaching plates to fences. They have a 3/8" hex head (I think),are hardened and you won't need to predrill in hard woods. I predrill in glue blocks though. They fit perfect in the Best Wood Tools faceplates. I use a cordless impact driver for them.
Google Simpsons SDS. I get them at Home Depot, but in qtys of 50 they are about $25.
Dick Hines
Dick Hines
>When I use a face plate I use self tapping sheet metal screws. I run them up with a nut driver in my drill.
Steven Antonucci
I use coated Concrete screws
Steve antonucci
>They have a really aggressive thread, are stronger than dirt, and wide enough to not wobble in the holes in my faceplate. If you accidentally hit them with a turning tool, you will be resharpening...
Steve
p.s. the ones I use also have square drive heads, which make them easy to drive and remove...
Carole Valentine
>Same here, Dick
Brian McKearney
Re: I use coated Concrete screws
Brian McKearney
>I use #12 Sheet Metal screws (2") - my local hardware store carries these with square drive and I have never broken one off. I drive with a Milwaukee decking driver and no pre-drilling. Once the square drive hole starts to round over, I know that it's time to toss that screw and replace with a new one.
Spax screws
keith zimmerman, Normal IL
John Jordan
>SPAX 12x1-1/4" n/m
Thanks for the responses!
david------WebKitFormBoundarylRgnhGioIdOlFg+1
>BTW, Jorge, I have heard that the tensile strength of stainless steel is less than that of regular steel screw metal. Have yet to try the Spax screw, but am seriously going to look at coated concrete screws. Probably try them both!
jim miles - Charlote NC
>In construction biz - put in a couple 100,000 screws, Do all my turning on faceplate & waste blocks, Some observations for faceplates: Stay away from drywall and deck screws they are too brittle, stainless steel is much weaker than the average screw, throw out slotted or Phillips heads, hex head or square drive much better, other comments in thread agree with my eperience: fatter size, pan head, use bigger number of shorter screws. The problem I have with breaking is in green wood, especially if left for a few days. Extract by drilling holes beside broken screw. Lowe's is starting to carry some new types that work well for faceplates.
Don Orr
>Me too when I use faceplates. I get the Tapcon brand at the local Borg.
Tom Vensel
>When I turn a segmented urn or bowl I always attach the waste block to the faceplate with 1/4" lag bolts . I always predrill the attachment holes and usually lube the bolts with soap .
Tom in S/E Ohio
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>John, I just ordered 500 of these. Thanks! I've not had any trouble with sheet metal screws, but I am taking your advice.
