Jet 1236
Jet 1236
Jet 1236
Barbara Gill------WebKitFormBoundarypTwA+e87REJF0d
>A friend has a 1236 that was bought used. The handwheel seems to be stuck. The instruction manual says nothing about a handwheel. There are no set screws. I am not sure which direction is loose on the outboard side of this lathe.
Standing at the outboard end of the lathe, facing the handwheel should the handwheel go clockwise or counter clockwise to loosen?
Re: Jet 1236
Rob Wallace
Re: Jet 1236 *LINK*
Rob Wallace
>Having owned a Jet 1236 for a number of years, and from what I've seen of recently marketed editions, the Jet 1236 does not come with a hand wheel on the headstock - one of the PITA "features" of this lathe.
If it DOES have a hand wheel on the headstock, it is likely an aftermarket add-on, and I don't know if a general question such as you have asked will yield useful responses unless more information about the hand wheel is supplied (....or perhaps if someone has the same add-on?).
Rob Wallace
Jet 1236 Manual (pdf)
Re: Jet 1236
Re: Jet 1236
>Thanks Rob. I guess that may be why the manual didn't even address it. I guess weight have to contact tech support.
Re: Jet 1236
Re: Jet 1236
Dick Coers------WebKitFormBoundaryv54aV+RmMmGf6euZ
>Every lathe I have owned has left hand threads on the outboard side. I've not owned one of these Jets, so only passing on past experiences. With left hand threads it's righty, loosey, lefty tighty. If it had right hand threads, the hand wheel would try to loosen every time you drug your hand on it to stop the lathe.
Re: Jet 1236
Re: Jet 1236
>Thanks Dick. That is what I thought but when it didn't loosen I thought I better ask.
Re: Jet 1236
Get a bigger wrench. Call Ruth
Russ Fairfield
Re: Jet 1236
Re: Jet 1236
Ron in Drums PA
>I put a hand wheel on the 1236 I used.
It has reverse threads.
Re: Jet 1236
Re: Jet 1236
Marc Phillips
>Interesting... mine came with a handwheel, and it was a righty-loosey thread... love these technical terms :) It also had a hole through it so that the knock out bar could be inserted to knock it loose.
Re: Jet 1236
Re: WMH part no, for those interested
Mike Hamilton
>I bought a handwheel for my 1236 before I traded up. It was handy but frustrating as it didn't come drilled through for a knock-out bar. I traded before I got around to having mine drilled. My notes have the part number as 708344-JWL-HW. It took them a while on the phone to dig this up for me to be able to order it. At least this will get the number into the archives. And yep, left-hand threads.
Regards,
Mike
Re: Jet 1236
Re: Jet 1236
Coyne
>My Jet mini has left hand (reverse) threads on the handwheel.
Coyne
Re: Jet 1236
Thanks for All The Help Everyone.
Re: Jet 1236
Some have right thread on outboard side
Don Evans
>Hi Dick:
Only an FYI (for some with less experience) -- my oneway 2436 has right hand threads on outboard side.
But Oneway uses grub screws on all their faceplates and vac adapter, etc. to keep them from unscrewing themselves.
I'm GUESSING, but I think all Oneways are made that way.
I think ALL lathe's should switch to that method, especially if they make their lathe reversible. It really doesn't make any sense to worry about it unscrewing in one direction if you can flip a switch and make it turn the other way.
Don
Re: Jet 1236
Re: Jet 1236 - Follow Up
>I went out and gave three good sacks to the rod I placed through the hole in the shaft of the handwheel. It came loose. Thanks for all the responses.
Re: Jet 1236
Roger in MO
Re: Jet 1236
Roger in MO
>How does the handwheel attach? The shaft of my 1236 is about flush with the bearing and frame of the headstock and is retained with a "C" clip. I have wanted to install a handwheel but can't see a way to do so. Maybe there has been a design change along the way. My machine is blue and it was purchased used.
Roger in MO
Re: Jet 1236
Re: Jet 1236
>The hole through the headstock is threaded so that the handwheel just screws in. The problem is that when it is in place the knock out bar cannot be used. Both the faceplate and the handwheel were very difficult to remove. I have suggested that she get a machined washer for each.
