SEGMENTED TURING HELP
Carl Barton
>I am a inpass. I made a really nice segmented cookie jar, all turned, sanded etc. In fact it looks pretty darn good and for the first time I made no major mistakes(only my third segmented turing).
I figured I would try to make a segmented lid vice using a 8/4 piece of stock. This is where I am getting myself confuse. I am cutting my segments from a 5 9/16 wide stock, I want a 7in outer ring, 10 segments for the ring. I have tripled checked my math and I came out with an 18 degree angle with the long side of the segments at 2 7/16 in length.
So I cut my segments, not twice, but three times this morning (wasted alot of stock). Still my segments are not fitting, I have almost a 1/2 in gap when I put them together. The segments are 2 7/16 in length, and 3 13/16 width. I have checked all my measurements,and angle on my chop saw three times.
Is there something I am not doing right when making long width segments than when one does from a segmented ring that is only 1 3/4 in width?
My thought was as long as you had the angle and length correct you could made the width of a segment as wide as you wanted.
Carl
