20 inch disc sander question
gary clarke
>Does anyone use a 20in disc sander and/or have experience with one? I know they are exensive and wonder what brand people have found adequate. thanks
Re: 20 inch disc sander question
Gary Evans Tallassee, TN
>I've used a 14" and it was scary enough to suit me. What will you be using such a big one for?
Gary
gary clarke
>Large segmented hollow forms
Ken
>What size lathe do you have?I have the Nova 16-24.and will be making a one this yr.Not sure what size it will be,probably around 18" as I can rotate the head.It will be a heck of a lot cheaper.I have the 12" sander'but want a larger one.
gary clarke
>Ken, I have a oneway 24/36. I am sorry but I do not understand what that has to do with a 20in disc sander unless you are suggesting that I make a disc sander to attach to the lathe with a face plate. Do you have plans to make a platform to fit the lathe at 90 degrees to the disc?
Wayne Allen (Carson City, NV)
>Gary - Several years ago I bought a 20" disc sander from Harbor Freight for $495.00. It appears to be exactly the same sander as the one sold by WoodTek for $995.00. After I bought it, I used it for a month or so and the capacitor attached to the motor blew out. It was still under warranty and they were going to replace the whole setup but they were out of stock and expected a 2 month delay in getting it back to me so I went to the local electrical supply and bought a replacement capacitor. For $14.00 and had it working the next day. It was a very simple replacement and it has worked great ever since. The thing is so finely balanced that it will keep spinning for about 5 minutes after you shut it off. Its a great addition to my shop, I wouldn't be without it. -- Wayne
Nick Tuzzolino
>I have the 20" Powermatic and did what Ken is thinking about doing. 20" MDF round attached to a faceplate. Built a platform 90 deg to the disk. Pretty good in lieu of $1700 for a real one.
Texian
>Ditto 15-3/4" disc sander for Jet 1642, but suggest particle board rather than MDF. Also built "table" with adjustable angle, mounted on 1" steel post that fits the banjo. Has the advantage of being variable speed, and never need to run it faster than about 300, sometimes much slower. Sanding disc lasts much longer and never burns the wood. I never sand individual segments, but do sand ends of half rings and half stave pieces. I sand individual stave edges on a 6x48 belt sander.
20" disc sander, State or Max are best
Robin Corell in Atascadero CA
>The best 20" sander ever made is the one sold by State Mfg. a just as acurate and slightly more affordable one is one made by the Max Mfg. The biggest difference between these two sanders and those mentioned by others in this thread is that the State and Max sanders have tables that are tilted with a geared hand wheel. both will tilt the table 4* for each full turn of the hand wheel and they both have a movable/indexable coller that is marked in full and half degree marks so that the tables can be acurately tilted with 100% repeatability.
Both these sanders are continuous duty industrial quality tools and a used one will likely cost the same as a new Woodtek. For what it is worth the Woodtek,Harbor Freight, and Enco, are all copies of a sander originaly sold as Apex/Rankin.
Robin
Re: 20" disc sander, State or Max are best
gary clarke
>I noticed that Laguna sells a 20 inch disc sander for much less than woodtek and wonder if anyone has experience with it?
