Turning tool holder/stand
GalenV in Iowa
>I made a lazy susan type lathe tool holder that will hold 12 turning tools in a vetical teepee fashion (have no picture tonight).
I seem to be making and buying more tools than I have a good place for them to call home. I think I have seen some pictures on Wood Central on some lathe tool holders but I can never sort back to them. I think some used cut lenths of PVC pipe in a rack or stand.
If someone has a good system I sure would like to see and adapt if it looks practical. Woodturning Design Spring Issue 21 has a traveling tool tote but not really what I need. Seems some are based on all the tools being close to same length and mine sure are not.
Before I just make a second holder like I got I would like to see some other designs if you will share.
Thanks
Galen
Re: Turning tool holder/stand
Re: Turning tool holder/stand *LINK*
charlie belden
>This one requires that you
a) have a good memory - or are willing to play That's Not It, That's Not It, Is This One Going To Be It?
b) really like making boxes - with trim and details
c) love solving puzzles
Acts as a tool stand or a lidded case -
someday with a carrying handle (on my
long To Do List)
Holder/Case/Stand
>Here is mine. The tool cabinet has all the other stuff, chucks, tool rests, vacuum chucks, buffing etc. The boring bars and cutters are all in Drawer 2. I started the tool rack with an orderly fashion of tools, bowl gouges on back right followed by spindle gouges and then went into scrapers and a section for skews. The back row has homemade tools for special uses and my ornament hollowing tools. I had lots of spare space. Then I bought more tools so now it's a little less organized but still very easy to find the exact tool I need.
Cyril Griesbach
>Here's mine. Design is from my friend Rob Nelson.
Don wilcut
>Looks a mite top heavy.
Don
Low tech solution
Ellis Walentine, Host
>I've tried a lot of different tool storage solutions over the years, and I decided that I wanted a method that would let me see the business ends of all the tools. I also didn't want to spend a week building a tool rack. So, a couple scraps of cheap plywood and some 8d and 10d nails and I was in business.
Peter Hyde
>I too have the lazy susan style tool holder and I augmented it with this one. It's the "tools in use rack" and allows instant recognition.
Steve Russell
>Hello,
I use a five foot tall mechanic's tool cabinet ($900.00) with sliding drawers for most of my tools and accessories. Other tools like hollowers and extra heavy boring bars are placed on a peg board wall with heavy duty holders. The holders shown in the follow up posts look great, but I have too many tools for any of these solutions to work for me. The top of my Unisaw is also used on occasion... :-o The Unisaw gods are angry... :-( The main thing is to have your tools easy to access and kept in a somewhat organized fashion.
Better Woodturning and Finishing Through Chemistry...
Steve Russell
Eurowood Werks Studio
The Woodlands, Texas
Mike Brazeau
>I put together an article a few years back that appears in a couple of places. The link below is one. It is a carousel on a small 4 drawer cart and a project oriented stand. I have since added some addition outriggers to hold things like my Oneway Coring system, tool rests, calipers etc. I am not one of those guys that only takes pictures when the shop is cleaned up! Follow the link to see the neat shots.
Couple of ideas
Carousel stand in current use
Mike Brazeau
>After snagging a brand new pair of jeans on a coring cutter, I recently added the shield on the top right of the outrigger for coring tools.
Mfoster
>This is my solution. It has worked for years, but is getting too small. My tool collection seems to get larger every year, I think they're reproducing.
GalenV in Iowa
>Thanks everyone for your input on lathe tool holder designs. It has given me some better ideas. As you can see by my current I failed to realize that I would be expanding my tool collection they could have even been closer spacing. This holds about half. I have a tool box full of lathe accesories and it too has filled up to capacity.
With concrete walls in the baement I really did not want to mount something on the wall and the cart/stand ideas look good.
Seeing the earlier post on how Serge used BBQ carts for stands seems like I could make a dedicated stand to hold a good share of all may lathe components and move them around. It is getting close to spring garage sale time and should be able to find one, if not setting by the curb in Ames.
Thanks again.
Galen
Russ Fairfield
>Taken when the new shop was still new and before it became filled to being crowded. One of the problems with the bigger building is that the walls are now too far away to use hanging tool racks and the ceiling is too high to use overhead anything. The walls were only 5 feet away in the little shop. Now they are 20 feet away and mobile tool racks are a necessity. I have a similar cabinet for sanding and finishing.
GalenV in Iowa
>Russ
Really having a hard time feeling sorry for yah with a shop that puts walls so far away. :>(
I'd give a lot just to has a window and sunlight in this rented townhome small basement corner with drab gray block walls!
At least it is dry!
Thanks for showing another idea.
Galen
Keith Tompkins
Keith Tompkins
>Here's one of mine, it's my travel carousel.
david
>This is an A-frame mounted on a standard utility cart, with things added to hold chucks, morse tapered accessories, and vacuum chucks on the top. Quite top heavy, but stabilized with dead weight on lower shelf of cart. Added a clear vinyl cover sheet pinned at the top to minimize shavings cluttering up the holes.
>I use flat shelves, some covered with carpet. I lay the tools on the shelves with the handles away from me and the pointy part towards me. This allows me to instantly locate the exact tool without having to memorize or decode some marking system. Those with very long handles go on deep shelves, some sticking out the back. This system requires minimal work to construct.
It is not a good system for those who may fall asleep at the lathe and reach for a sharp skew without looking.
I like this method also since it is flexible in organization - as my tool "collection" and favorite set changes, I can easily rearrange as needed. I put all the skews together, etc. Those tools seldom used are on the highest shelves. Floor-to-high shelves are positioned to the right with a shorter stack at the right rear of the lathe so nearly any tool can be reached without moving my feet or twisting behind. Chucks and other often used things are on the lower right shelves.
I've tried several things an this is a far better solution for me.
keith zimmerman, Normal IL
>Here's mine. It works really well for me, but it's now too small.
GalenV in Iowa
>Looks like a lot of good ideas with one thing in common to them all.
No matter what you build it will always be too small!
Thanks again
Galen
Great thread-shouldn't we save it?
George in Minnesota
>I would think this would be a great addition to the articles section.
Re: Thanks everyone for your input
That's one reason I went with simple flat shelves. I have plenty of space (seven shelves at the moment I think) but when I ran short of space last year I simply subdivided some shelves that were taller than needed with pieces of thin plywood. It takes only a few inches of vertical space for a row of gouges laid flat.
Very short or very long tools are no problem with open-back or deep shelves. For most of the long tools I use an adjustable wire shelving unit placed at the tailstock end of the lathe and slide the handles into the sides of the shelves rather than the front.
Now, if I could just find some time to turn....
OK John I was in error :>{
GalenV in Iowa
Your tool storage is not too small. You are just able to stuff more tools in the same storage space with modifcation.
I might have been closer if I had said what we have in common is we all have to modify our tool storage to make room for more tools.
They say my inner carotid artery is 45% blocked and that one feeds my brain. It appears it is beginning to be more noticable! Here I thought it was poor blood flow to my heart that would get me first.
oxygen to the brain
>The way my brain is deteriorating, I must have the same blockage.
I knew a guy who would, in the morning and several times during the day, breathe a shot or two of pure oxygen from some tanks in our lab. He claimed it cleared his head and made his brain work better. (He was a very energetic, creative, and intelligent fellow.) Since it probably did increase the oxygen level in his blood and thus his brain for a time, he may have been on to something. He said he kept a small tank by his bed and a shot of O2 cleared the cobwebs and brought him instantly wide awake in the morning. I found that a few deep breaths when I first wake up does the same thing, but I'm usually too groggy to remember to do it! I also noticed I have a much harder time waking up and thinking clearly when I have sinus congestion, which is often.
Maybe we should add a hose to feed extra oxygen into our turning respirators.
Make mine nitrous oxide I need a laugh! :>)
GalenV in Iowa
