new chasing tools
new chasing tools
new chasing tools
>Well I had to stay home today so they could install my new HVAC unit so I made the best of it (please don't throw me in that there briar patch). I spent the day in the shop making chasing tools. I used a modified system similar to what Fred Holder described using a tap.
I took a nut of the appropriate size and cut a slot that fit the metal that I used to make the tools. Then I made a cut in the back of the nut to act as a sort of hinge.
I insert the steel into the nut so it sticks slightly deeper than the threads and clamp the whole thing in vise. Then I just run a tap down through the nut threading the steel. It�s a little hard to get started straight but once you make a couple of revolutions it cuts right down.
To improve the threads I took a triangular file and carefully matched the angle of the threads and took the same number of passes on each tooth down the middle to create a deeper and sharper tooth. I also filed off the outside partial tooth. Try not to change the angle of the tooth. I filed the 16TPI outside cutter at a slight angle accidentally. It cut as fast as a 10 tooth threader. I went back and filed the teeth almost perpendicular to the top surface and now it is very controllable. I polished the top side of the tools using diamond hones.
I made 2 tools. One using a 5/8 x 10 tap and one using a 7/16x16 tap. You can�t use a small nut so instead of using a 1/4x20 tap use a 1/2x20 fine thread tap to get 20 TPI. I made these from some tool steel that I had. I think you could make these from old chisels by annealing the tip cutting the threads and then reharding and tempering. If you need to know how to do that just send me an e-mail and I can send you a document on heat treating. I haven�t tried using a chisel yet but it should work. If I have time I�ll try it this weekend.
Re: new chasing tools
nut and tap
slotted nut
finished tools
>I made handles by routing a groove in a board and then gluing another board to this. I drilled and put a threaded insert into the handle before gluing the boards together. Then I just centered them on the lathe and turned them.
Since the tools are double ended I made the handles long enough to completely store the tools inside. For use you just pull out the side you need.
These are like the Mark Stleger tools but made using just a hacksaw, tap, flat file, triangular file, and a grinder to shape the steel.
John Veerkamp,Western Mo
>They look great John, it even soungs easy enough for me to try. Thanks for the lesson.
John
Steven Antonucci
That's freakin' brilliant!
steve antonucci
>I may just have to add that to the list....
Steve
Roger in MO
Roger in MO
>Very creative (as usual)John. Also a very good description. How are these used? Tool on the rest? Lathe under power? Techniques and pointers?
Roger in MO
Re: nut and tap *LINK*
Fred Holder
>John,
That is an excellent technique. It would work much better than clamping the steel between two pieces of wood. Great addition to the hand thread chasing program.
m
GalenV in Iowa
>John
I'm just like an excited kid seeing a new toy! Thanks for the great detail on your fabrication. Will be looking for posted pictures of how they work.
With the cuts in the nut I assume you ended up cutting some new threads in the nut the same time you cut the bar or did you clamp the bar set back and tap the nut out first and then slide the bar into the depth to cut?
Since the nut was slotted on centerline your cut teeth had a slight curved face. Maybe this was filed flat as you dressed? If you only cut threads with the upper surface profile would slotting the nut off center be an advantage or maybe not? Thinking of how a Sorby beading tool has the half round at a slope to the steel thickness.
I have not seen anyone hand chase threads in wood so what you are showing is really new to me.
Thanks
Galen
Thanks for your help.
>The tool is on the tool rest and you sort of make an oval motion. Touch the wood, move toward the headstock letting the tool lead you, and then pull the tool out, return to the start and do it again. It helps if you read Fred's book and maybe watch one of the video's to see how it's done. then it's just a matter of practice.
I'm not good at it yet but I am learning more every day. I would say it's kind of like the skew. The more you practice the better you get.
>My commercial threaders have more slope to the thread. I believe I could make these by putting a cutter in the chuck of my metal lathe and mounting the steel in a vise on the powered crossfeed. By mounting the steel a little above center you could get whatever slope you want to the threads.
I'm still to new at thread chasing to tell you if there is any advantage to having a steeper "bevel" to the cutter. I would think it might cut a cleaner thread.
This would be easy to do with the file after you tap the thread. Just angle the file down more as you clean up the threads and you could make what I'll call the bevel steeper. By the way you don't rub the bevel on these tools. I find that I need to use them almost flat and very slightly above center but I'll take any advice anyone can give, I'm still learning.
Re: nut and tap
paul waddle
>I can understand the nut and tap-this for an external cutter right?pw
Alex Yeilding
>You make it sound harder than it is. I'm just a beginner, and I've already mastered the spiral cut! ;-)
Don Orr
>I'll say it again John-you are amazing ! That is just an outstanding idea. The finished product is superb. Very well done.
I must have been too tired last night.
>I understand what you are saying now about cutting the nut in the middle. If you simply move the cut slightly to the right on this example the tap will cut the steel with a slight downhill slant looking at it from the top. This would more closely resemble the Factory tools that I have. I'll try that when I make the tools out of a chisel this weekend.
Re: new chasing tools *LINK*
Mike Hamilton
>Nice work John. A coupling nut might give you some room to get the tap lined up before you hit the tool steel. Longer cut to set it up though. Local hardware store ought to have several sizes to choose from.
Regards,
Mike
coupling nut example
>Mike Good thought. I can't get all sizes locally but it would be worth trying. I know they have them in the common course threads.
