>So I know there's a ton of reasons why I should have dust collection at the lathe, but I'm curious how many people actually do? I have a dust mask I wear when I'm sanding (not as much as I should, but I do).
If you do... what kinds of setups do you have that you like and work for you? What have you found has been a pain in doing so?
>I have the Oneway dust hood on my Oneway lathe connected by 6" spiral metal pipe to a 3hp cyclone dust collector. That may seam like overkill to some folks. But the fact is that no dust escapes when sanding a 20"+ platter. This dust hood doesn't get in my way, provides mounting points for two moffet lights and provides considerable temporary tool storage space. Eliminating dust, not shavings, adds more convenience and is designed to easily get out of the way. Is this dust control perfect? Far from it. The cost with dust collector is $1700+. There is some small effort to "adjust" the hood for different cuts. If the dust hood didn't collect dust I might keep it anyway. The system collects dust with almost no effort on my part. The best thing I have ever done to control dust at the lathe.
>My lathe is at the front end of my garage workshop. I used to have a large fan blowing the dust outside. My neighbor complained about dust getting in their windows about 60 feet away. Got a Jet 1100 CFM collector with 6" hose connected to a collection hood on a floor stand that I move into position when I sand. The collector unit is exposed less than 10 feet away. Don't like the noise, and I would guess about 70%-80% of the dust is sucked up. Also close my shop door during extended sanding sessions. Still have a layer of dust all over my shop, but no further compaints is a good thing.
>I have a homemade, four-fiilter air cleaner right above my lathe. I have two exhaust fans in the window about 20 feet West (in front of me) of my lathe, and a floor-stand fan just to my left rear, blowing across my left shoulder, and another fan ontop of my referkiln to my right front. The floor fan blows across my large lathe towards the window. The refer fan blows across my Little Vic, towards the window. The eaves are open in my shop, and in the summer, I open the door, which is behind me. I never seem to have a problem with dust... in my nose, that is... the inside of the shop is covered in it. About twice a year, I give it a good dusting with my air gun. :o)
>I clamp the 4" hose that goes to my DC on the back side of the piece when I'm sanding, and I put a floor standing fan behind me so that the fan is slowly blowing air towards the piece.
I think that using a fan is a very underrated method of dust control. Dust doesn't swim upstream.
>I've got a "floor stand suction head" visible underneath the leg. I do a fair bit of spindle work and it is nice to have something to lay the templates (and legs or stretchers) on. It is hooked up to my DC system (2 hp cyclone). It works well for spindle work - not so good for bowl work. I change the head out and put a hood on the stand when doing bowls.
I usually wear a dust mask when doing "nuisance" woods like walnut, cocobolo or spalted woods - as well as using the DC system.
>I use a small box filter that I can set right beside the lathe. I place a larger box fan behind me, which blows across the turning into the box filter. I also try to get as smooth a surface through shear scraping, then wet sand from 400 grit up to minimize sanding dust.
The box filter is made by the folks that make the Razortip pyrography equipment (see link). It allows you to stack filters in series, is quiet and has an adjustable speed control. They even make filters with activated carbon that help reduce smoke smell if you are doing wood burning.
I tried the conventional dust collector route, it just made too much noise and added too much heat for my air conditioner to overcome. This route seems equally effective (based on lack of dust in shop and/or tissue test). I also have a half face HEPA mask that I can supplement all of the above if needed.
>I bring the 4" hose for my DC up and hook it into the banjo/tool rest close to the piece when I sand. I play the stream line air game. See if can get the stream of dust directed into the pipe.
When I installed my DC I left a 6" port for the lathe, but I have never hooked up a hood to it. Most of the big curls come off the front. I doubt a hood behind the lathe would catch much of it. It's the dust that is harmful to your health. Go after that.
>I have a dust collecter hangind right in back of the head stock. The best I can say is it works good. I have found out you never can collect all the dust. I don't think it can be done.
The best you can hope for is getting most of the dust. M
>Before Oneway maid theirs, I made one out of a 55 gallon white plastic food grade drum (cost about $10). Cut part off one end and covered it with clear plastic, cut off some of the front, cut a hole for the headstock spindle to go through, put a hose on the back. The bottom sits on the lathe bed by having a piece of plywood screwed to the bottom that fits in the ways. The bowl is almost totally inside, and with me standing in front, a little dust will get on my smock, some on my arms, but none up my nose or on my glasses. I have checked after sanding black walnut for 6 hours. The more a hood encloses your sanding, the less dust escapes into the shop. Fans and filters will work almost as well, if you have a hood around them and what you are sanding, but a dust collector can move more air. Power sanding will throw more dust than hand sanding, but even hand sanding throws dust that a hose or fan won't get. Fans to tend to stir up what dust is lying around. If you don't have a hood, you HAVE to wear a dust mask at least and a respirator is better, especially if you have a beard.
