Small Rotating Platform
david------WebKitFormBoundarylRgnhGioIdOlFg+1
>Temporary display venues don't normally have provisions for highlighting your pieces, especially if you want to show its translucence. Thinking that a LED puck light would provide some light if placed on the inside of the bowl shining on the walls. This light is pretty directional, so it creates a hot spot. Not so bad if the light source moves, or rotates from within. Any idea of a small (under 4" dia.) battery-powered device that has a slow rotating platform, sort of like a lazy susan? Another option would be to display along side the piece a photo taken with it lit up. TIA, David
Re: Small Rotating Platform
Mark Wollschlager
>The spring 2007 edition of Woodturning Design has an article by Peter Rand on making a slow turning pedestal.
That might be a place to start.
Mark.
Scott in Socal
>A mirror ball rotator motor might be a good place to start. They plug in to the wall, but rotate very slowly. Would probably be pretty easy to attach a platform/puck light to the rotating hook, and they are usually about 3" diameter and 1-2" thick.
John Scheideman
>You can Google: Kaleidoscope Designs. They have the lights but I don't know about the rotation.
John
Re: Small Rotating Platform *LINK*
Tim Browne
>This is pretty close to what you're looking for. Most of these have the lights built in but you could cover them if you want to use your own.
Rotating 7 LED light 3d Crystal display Stand base
Harvey Brooks, Victoria, BC
>Here's a link to a source for battery operated turntables.
Harvey
http://www.sportcraftcars.com/display_turntables.htm
Thanks all! Just what I needed!
david
