Does anybody have a several years old Craft Supplies catalog handy? I need to figure out the shipping weight for a 20" short bed Woodfast lathe. I know it's been a number of years since they sold them.
I just can't figure out how to weigh the one I have.
I looked in an 04 Craft Supply catalog and they don't list the weight. They just say (Prices are Freight Collect). They say "Woodfast lathes are shipped by truck, call for a freight quote".
>The Spring 2003 Woodcraft Supplies catalog states the net weight of the M408 model, 16-inch shortbed, is 385 pounds. Add 100 pounds for the additional weight of a 20-inch model and the crate?
I've weighed goats too big to pick up (200lb+): have them stand on a board suspended between two bathroom scales then add the two weights. If you had a way to hoist the lathe, you could lower it on a platform supported by four scales, one at each corner. Finding four bathroom scales might be a problem.
If the lathe was easy to load into the truck you could drive through a truck scale with and without the lathe.
The local meat processing place has a scale on a hoist with the capacity to weigh a cow. If you could borrow one of those you might lift the lathe with a come-along from the rafters.
Does it come apart easily? Might be possible to weigh the pieces separately.
>Weigh each end independantly with a bathroom scale and add the two weights together for the total. You may need to put a board between the feet at each end with the scale in between. Those scales typically will weigh up to about 300 pounds.
Rikon still lists a long bed 20" Woodfast lathe, which is just under 600 pounds. If you subtract, say, 100 pounds for the added bed length, it is around what one of the other posters recalled.
>Good ideas John. Unless this guy I'm talking to comes across with some money, the lathe is going to stay firmily bolted down to the floor at the store. I've actually started using it again.
>I can saw a log or three practically any time after this coming week. (Anything but black locust.) You said cedar, right?
I have some freshly cut cherry and poplar to cut also.
I'm in the planting mode this coming week as soon as it quits raining. I have about 50 trees and shrubs to put into the ground while I still have the backhoe on the tractor.
