>Has anyone had any experience with the elbo tool marketed by Stan Townsend? I used one while attending a class at John C Campbell last week and am considering taking the plunge and purchasing one. If you have one what if any issues have you had.
Other than using the Elbo tool at a demo, I don't have much experience with it. As positive as that experience was (It was very positive. Stan was great to talk with and the tool operated very smoothly.), I went a different route when I bought an articulated arm hollowing tool last year. My reasoning: The Elbo Tool attaches to the tailstock. On my short-bed lathe (a Woodfast), that would have left virtually no room for the blank to be hollowed. Instead, I went with the "Monster" Articulated Arm Hollowing System from Randy Privett. Instead of attaching to the tail stock, Randy's articulated arm comes with a tool post that mounts in lieu of the tailstock. This allows me to mount a hollow form blank that is at least 12" deep -- 8" to 10" deeper than the Elbo Tool would have allowed.
In fairness to the Elbo Tool, I could have achieved the same result by making my own tool post. I could get even greater depth (with either tool) by making a floor stand supported tool post. The Monster was just a more convenient solution for me.
>I have been using the Elbo tool since 06. I upgraded to the joint bearings in 07. I use it on all my hollow forms and on a good portion of my boxes. I have used it on bowls of all sizes whenever my shoulder is bothering me. A Great tool.
Bob Rogne. WestMac Turnings in Mesa for two more months
>I have three Kobra articulated systems made by Jerry Arnold (earlygrandpa@yahoo.com, 765-534-4437)in Lapel, Indiana. I can't say enough good things about the tools and his service. Everything I have asked for he has done. It works very smoothly, is very easy to set up and it does not rattle. The tension on each set of bearings is adjustable. The original systems were mounted so the first (lowest) pivot point was centered up on the bed of the lathe. They have since started supplying a 1/2" thick plate that moves the pivot point behind the bed of the lathe. This is very helpful because it increases the reach when you need to use a longer shafted boring bar and/or need to reach under the opening in a hollow form. A 1" diameter hole with set screws accepts the standard 1" boring bar. The have optional adapters to enable the use of boring bars of, 3/4", 5/8" and 1/2" diameter. The boring bar tool tips- there are three; straight, 22.5 degrees and 45 degrees are interchangeable. The tips have square broached holes so you can install square tool bits without having to round the shank. I actually sharpen both ends so all I have to do is turn them around. I have two sets of three tips; one set accepts 3/16" and the other set accepts 1/4". Hunter bits that come mounted to a square shank can be installed without having to round the shank. I have also been usng carbide tipped bits, used widely by machinists, (sharpened on a diamond wheel or a green wheel) that come on a 1/4" square shank. You can turn with one of these all day long before needing to re-sharpen them.
The laser system that comes with the Kobra is mounted to a square shaft to prevent you from shooting at an angle. It is not a cheap pencil style of laser. It is very cleanly mounted with wires that are hidden inside the square tube that run to a battery/switch box. The switch bow is mounted upside down so dust will not settle into the switch. This is just one example of the many superb features of their system. I have no financial connection to Kobra.
I have been using the Elbo tool for over a year and am well pleased with it. The tool uses 1/4 inch square bits which are available and inexpensive. I have adapters to use other tools with 1/2 and 5/8 shanks which makes it very versatile. I use a variety of straight and bent shank tools with it. It is quick and easy to mount and remove from the tailstock.
>I have three hollowing rigs, a modified ElboTool, the Spindoctor, and the Don Derry. Without question, the one I turn to nearly all the time is the modified Elbo. The modification consists in getting rid of the silly attachment to the tail stock and substituting a vertical post that goes in a second banjo. So, yes, you have to have a second banjo. As for the vertical post, Stan will make one for you. If you're handy with metal working, it's no big deal to make it yourself. What I prefer -- big time -- about this rig, which I don't get with the others, is that there is basically no friction and nothing to hang up. The elbows simply pivot in air. Of course, the business end of the actual cutting tool does ride on the tool rest, but that doesn't ever cause any hang up. I don't care for Stan's laser attachment, though; so I got the Oneway, which is far superior. For very large pieces, I do use the Spindoctor. The advantage of the Derry is that it is extremely fast to set up and his x/y adjustment for the laser is superb. But I find that no matter what I use to lubricate the flats that hold the square tools, there is sufficient friction to cause binding. Good luck with your hollowing( and remember, too, that a master like Ellsworth doesn't use any constraining rigs.)
>My homemade Jamieson bar has all rounded tubes. If I lube with candlewax there isn't any friction at all. I'm always astounded how little effort it takes to move the tool.
>Before you go with a captured hollowing system you recently got to try - you might want to look into what's available.
Couple of general questions you might want answers to
1. How is the tooling held?
Round holes are easy to drill and roundinsert tooling to fit the hole is readilyavailable. BUT - when a set screw is tightened down on the insert - it dimples the metal. If the hole /insert tool fit is snug to tight to begin with - you may not be able to remove the tooling, or if you can, may not be able to insert it again - without a little filing or sanding.
This one's easy enough to fix by filing a "flat" on the tooling shank - in the right area. Guess wrong and you won't get the right cutting/scraping angle - and that's a problem.
2. How much of your available length capacity does the system take up - if any.
3. How easy is it to adjust the tail stock end's height? These things work best when the cutting edge is at or a tad above centerline and the cutting edge is angled properly.
4. Are there safe gripping locations that keep your fingers from being pinched between moving parts?
5. Do the joints have bearings or merely two holes with a bolt or pin connecting them?
6. Does a laser set up come with it or is that an accessory - which adds to the price?
7. How easy is the laser to set - and how well will it be kept there once set? If it moves
and you don't know it - that's worse than having no laser at all.
8. What insert tooling comes with the unit?
If you have to buy several more cutters to really use the capabilities of the unit, the price can go up - some times a lot.
9. Do you HAVE to get insert tooling from the source you purchased the unit from or can you use insert tools from other sources?
10. How much fun and games will you have to go through to store the whole set up when it's not being used - and how are you going to keep track of all those parts? How much space will it take to store - everything? Do you have to take everything apart to store it or can it be stored assembled and ready to use?
Attached is the url to a compendium of captured hollowing systems I put together when I was investigating for a purchase.
I ended up going with the MiniMonster because it was a pretty complete package at an affordable price - no accessories/options to have to buy. I don't lose and length capacity on my JET mini and storing the assembled unit - and its accessories - doesn't take up much space at all (see link at the bottom of the referenced web page)
>Thanks. But I attached the wrong url. Here's the one I MEANT to post which has all the Captured Systems I could find BEFORE I made my selection and purchase. I suspect more have been added since.
>John, Thanks for bringing up a critical point. How easy does it move?? Does it move without flexing under load?? Will it move easily when hollowing...like when cleaning up tool marks and making nice flowing shapes on the inside of your hollow form??? I want to be in total control when I have a boring bar hanging out over the tool rest.
