Finnishing Napkin Rings
Ed Conhaim
>Need some ideas...Please
Have some maple napkin rings off the lathe. I need to finish them for gifts. Some natural and others I thought to stain darker. My question is after the staining, what can I use as a finish keeping in mind that they are off the lathe. Should I try to put a few coats of poly on them or would buffing with carnuba work? Any thoughts appeciated.
Re: Finnishing Napkin Rings
Brad Vietje
Brad Vietje
>Ed,
I'll be interested in the responses you get - but...
...just because they are already *off* the lathe, that doesn't mean you can't put 'em back *on*, if that opens up a finishing method you would prefer to use. You can easily make up a little friction chuck or fashion some way to hold them between centers (imagine two opposing cones, for example). If rotary application and/or friction and heat are important, you can also use some sort of buff-thingy on a drill press or mounted on the headstock to do the inside, too.
Just a few ideas...
Brad Vietje
Newbury, VT
Brad Vietje
That's Finishing, not Finnishing ;~)
Brad Vietje
>...but if you ARE going to take 'em to Finland, I'd wait till summer!
BV
david
>I like Brad's idea of opposing cones for working on them between centers. If they are round on the outside applying some cushioning on the jaws of a chuck might work in the expansion mode using some friction polish for the finish. If you are able to fashion some kind of suspension system, a can of Deft spray lacquer works well.
Skip Beardsley------WebKitFormBoundaryo2PSwy+o0IUR
>Ed,
I have been making wooden bracelets and have found it easiest to finish the outside before cutting the inside. Then all you have to do is sand and finish the interior. One option is to make a jam chuck if it is important to apply the finish to a turning ring. This might be the case with a friction polish. I have use this approach and it really works well.
Another option is to put some rubber bands on your chuck and then expand to the inside of the ring. BE CAREFUL if you do this as any excess pressure will crack the ring.
Hope this helps.... good luck.
Skip
Ed Conhaim
>Thanks for the info. If I just want to finish them off the lathe can I stain them and then apply some type of finish to both inside and outside? And if so, what can I put on them that will look good? Once they are stained can I three stage buff them and get a respectable finish? Just looking for opinions/options here as I have never tried this before.
Scott in Socal
>I'd try some Arm-R-Seal by general finishes. It's a wiping varnish that is really durable and self levels really well, super easy to apply. Three coats will give you a great finish.
