glues for wood to metal and ...
paul waddle
>I want to glue some wood to metal(aluminum). And I want to glue some aluminum to aluminum . What is the best type of adhesive for this-been told there is an Eastman product? Thks,pw.
paul waddle
Re: glues for wood to metal and ...
david
Try: thistothat.com
david
Dick Coers
>I've glued copper to western red cedar with Gorilla glue. Held just great and it was an outside application.
Re: glues for wood to metal and ... *LINK*
Stuart Johnson
>Try this link.
This ToThat
>Elmers F26 works well to glue metal to wood. It stays a little flexible however it's tan so it will show in some joints.
epoxy works well if you add some mechanical bonding details. I scratch the side of the metal so the epoxy has something to grab onto.
Contact cement works well but can be heat sensitive so it depend on the function of the final product as to whether it will work.
CA glue works well on metal to metal if both surfaces are polished and there won't be any shear load.
GalenV in Iowa
>We used Masterbond epoxy adhesive to glue wood to aluminum, aluminum to aluminum, and Formica to aluminum and on epoxy joining of aluminum handrail fitting. Most of these were in humid or outdoor locations.
Galen
Masterbond
Fog Tanner
>I just got through running some tests for my daughter using epoxy. She has a need to glue some metal and glass to wood and glass to metal. I used some 30 minute epoxy made by Bob Smith Industries with good results. I can't get the glass or steel off. You can find this epoxy at almost any model shop, usually with the store's name on it. Some of the smaller woodworking shops will carry it. If you buy enough Bob will put your name on it.
I have used it for over 20 years on fiberglass, wood, steel, and composites - but have never used it on aluminum. You can contact them and they will be able to tell you or just run a test.
Fog
