At What Speeds Do You Turn?.....
Wally Dickerman in Arizona
>In my opinion most turners turn at speeds that are too slow for best results. At the Desert Roundup symposium I attended 2 of Cindy Drozda's demos. At one of them she turned a 3-sided vessel. which means that she changed centers to achieve the 3 sides. This also means that the blank was unbalanced. The blank was about 4 inches in diameter. She cranked the lathe up to 3000 RPM! The lathe was a 16 inch Jet and it wasn't weighted down. She did a beautiful job.
I live in a retirement community and we have a community woodshop that has 8 lathes. I have my own shop but I visit the community shop frequently (I taught classes there for years). I have observed that most turners are over-cautious and turn at speeds that are way too low for best results. Most don't crank it up to over 1000 RPM.
Most of my own turning is under 10 inches in dia. and I regularly turn bowls and vessels at between 1500 and 2000 RPM, depending on the wood. Spindle turning can run up to 3000 RPM. I find that at higher speeds I get better, smoother cutting, and I really believe that there is less chance of an accident.
Of course safe turning has a top priority so we have to use some common sense when selecting speeds. Don't crank up a segmented vessel to 3000 RPM!
What speeds do you turn at?
Wally
