glue
glue
glue
jack
>has anyone used E6000 GLUE IN THERE PEN MAKING ? IF THERE WERE ANY PROBLEMS WHAT WERE THEY?
THANKS
JACK
Re: glue
Re: glue
Harry In beautiful downtown Kulpsville
>I don't believe there is an application for E6000 in making pens but I could be wrong. I've always put this adhesive into the contact cement class. I've used in when making book marks to glue the little wood piece to the metal part. It seems to work well in this application. I only use Polyurethane glue to glue pen tubes into the wood blanks. I've tried using CA but have had a couple failures and don't intend to use it again. I can't see any advantage to using E6000.
Re: glue
Re: glue
Al Neighbors
>I use E6000 for craft projects only. I don't think it would be firm enough for pens... but then there's not much space between the tube and the wood, so it might work. However, you could use 2-ton epoxy... it would cure faster. If you glue tubes, then wait 'til tomorrow to turn them, E6000 might work okay.
I use 5 minute epoxy. I can turn them about as soon as with gel CA.
Re: glue
Re: glue
GalenV in Iowa
>Seems lke E6000 glue would be way too thick.
I just use 100 grit sandpaper on the brass tubes in randum pattern scratches. Then wipe clean. I run a large pipe cleaner through the pen blank just to insure I get any loose materials out. I use Stick Fast CA medium for wood and the flexible for plastic pens. Only had one brass tube in dozens slip when pressing pen part. I probably use more than I need. I turn the brass going in and QUICKLY slide partially up and down once. I do a few at the same time and then let set as I usually have other things I can do and insure they are solid before triming ends and turning.
Galen
Re: glue
Re: glue
Ed Conhaim
>Started penmaking using thick CA glue and hated every minute of it. While most of the time the glue held (not all the time), the mess and glue on fingers was a real pain. A highly experienced penmaker in our club suggested SUMO glue as the better urethane glue compared to Gorilla glue. It is from the same company but supposedly does not foam as much as Gorilla glue. The only problem is that the set up time is basically overnight. I got around this by glueing up a group at a time.
