3 sided box
robert davis
>looking for tutorial for three sised box...thanks/bob davis
3 sided box
robert davis
Re: 3 sided box
Harry In beautiful downtown Kulpsville
>Go to Cindy Drozda's site. She has a tutorial on a three-sided box. I saw her make one at Totally Turning 2006. A very talented lady.
Re: 3 sided box
robert davis
>harry went to her site didnt find any tutorials...bob
Re: 3 sided box *LINK*
charlie belden
>There are two tricky parts to turning a 3 sided box - aside from laying out the three centers.
The first is turning the intersecting arcs so they intersect where you want them to intersect. Repeatedly redrawing lines down he side of the blank helps. Use the tool rest as a straight edge and line it up with the lines the three centers lay on and draw lines down the outside of your blank. This means creeping up on the intersection rather than trying to turn ALL of Arc #1 before starting on Arc #2, completing Arc #2 and then doing Arc #3. That approach may work - but the box will probably be a LOT smaller than it could be.
The second tricky part is the hollowing - while not turning through the sides of the box. Because the box probably won't be exactly symetric, keep checking ALL face thicknesses and not just one.
Drozda 3 Sided Box Layout
Re: 3 sided box
GaryG in MD
>Bob,
Mark St. Leger makes small, three-sided boxes by turning cubes on point. See www.markstleger.com/Rock-A-Bye%20Box.htm
These are much easier to make than Cindy's -- if you like the idea of something simpler...
...Gary
Re: 3 sided box
Wally Dickerman in Arizona
>Yesterday I watched Cindy D. turn a 3 sided vessel at the Desert Roundup Symp. in Mesa Az. She's very good. To those of you who are hesitant to turn at over 1000 RPM, you'll be interested to know that even though a 3 sided vessel requires changing centers 3 times, which makes the piece unbalanced, Cindy cranks the lathe up to 3000 RPM. Don't try this on a mini lathe or you may have to chase it around the shop. She was turning on a Jet 16 in. lathe.
Wally
thanks for the info..!!!
robert davis
>Try this link.It was on her site but not very obvious.
http://www.cindydrozda.com/html/Handouts.htm
