Re: Paul... where did you learn to...
Paul Waddle
>Galen found you a cutter and I hope it works,I just figured the cutter was too small,the one with a 1/4" shank. You can look at John Lucase's threader,at mine and the one by Crawford(?).You can buy Bonnie Klein's very good vhs tape on thread cutting and it shows a home made cutter-very similar to what you want.It also goes in to detail about thread cutting.
You can buy all thread,if its straight,you're all right-get a 3/4-16 and a couple of nuts. If your lathe is 3/4-16 as some of the starter lathes are,you have the major componets. You indicate you have a cross slide vise,so give it a shot. As you go,you can then ask questions and will understand. The problem of doing this is: Althread is usually not straight and the fit is made kinda sloppy. Nevertheless,give a try.
I too am on a fixed income,otherwise, I'd buy a Baxter and stop all this makeshift stuff and go first class. I'm nearly 70 so I doubt if you're much older than I,if you are,you're spunkier than I.pw
