>I would like to compile an injury database for WoodCentral.
I want ya'lls own stories, not 2nd hand stories (unless you witnessed the accident/injury.
I would like the following data:
Name - can use a nom de guerre
Date - approximate is good enough
Experience Level - i.e. beginner, intermediate, expert
Tool responsible - lathe, band saw, table saw, etc.
Type of injury - cut, bruise, etc.
Severity of injury - how bad was it, did you have to take time off of woodworking, work, etc.
First Aid? - was first aid administered? Was it all that was needed?
ER visit or Doctor's office visit - was it necessary to go to the ER or an Urgent Care facility (or Doctor's office) for the injury?
Follow up medical care - such as physical therapy, further surgery, etc.
Preventative measures? - what could have prevented the injury?
I don't want to clog up the Board with injury reports. I'll be going through the archives to try and compile data from there. If you feel like participating, please email me your data. TIA.
>Your request is timely in my case. I'm recovering from recent eye repair surgery and I'm looking for sympathy anywhere I can get it. ;)
Date of Accident: Spring 2008
Experience Level: Heavily experienced in carpentry�building, cabinet and furniture making, etc. (About a year experience with wood turning).
Tool in Use: Claw hammer and chisel.
Type of Injury: Small chip of wood went ballistic and hit my eye with unbelievable force. I was removing old porch rails. I couldn't get the screws loose from the post. I sawed rails off about an inch from post and was using cold chisel and hammer to split the end grain of the remainder.
Severity of Injury: The impact of the chip cut the cornea and damaged the lens and the structure that holds the lens. It caused an immediate sight inhibiting cataract and trauma induced glaucoma (pressure).
First Aid: We made a flying trip to the nearest eye clinic, thirty-five miles away.
Follow-up Treatment: I made numerous follow-up visits prior to the surgery. January 15, 2009, I underwent cataract surgery�with complications. The Ophthalmologist, whom I hold in extremely high regard, told me early on that cataract surgery (lens replacement) would be very complicated because of the damage to the support structure. He was right. It took almost two hours to do what he's famous for doing in under fifteen minutes. The final results are not yet known, but we are hopeful that after another bit of laser surgery I may actually recover reasonably good sight in the eye.
Preventative Measures: EYE PROTECTION! Before anyone starts preaching to the choir, I'm almost fanatical about safety. I own three full face shields, dozens of goggles, ear protectors, hard hats, etc., and I use them... about ninety-five percent of the time.
>Well I guess I will be next on the list for an injury. It has been a long time since I have shed any blood in the shop but now that we have a list I expect I will be there soon enough.
>JL,How about dropping the question "Tool Responsible" and change it to "Tool or Machine in Use" when accident happened. Also add, "What Did 'You' Do Wrong to Cause the Accident?"
>Jerome, I have become so prone to minor cuts in the shop I was given my own first aid kit the last time I went to John C. Campbell and had to use it the first day as I cut my thumb while I was unpacking my turning tools. At least the tools were sharp...
Right now I am nursing a paper cut I received while reading the American Woodturner AAW Journal....
>There was in incident at the Florida Woodturning Symposium in January during the "Turn Around" competition. Each team was giving a block of wood and instructed to turn a box. While the teams were mounting the wood on the lathe and getting ready to turn, one of the guys turned his lathe on and it made a funny noise. He stopped the lathe, checked things over, and turned it on again. Still making a funny noise, he started to turn and as soon as he touched the tool to the wood it flew off the lathe hitting him in the face. He had to get several stiches and had quite a bit of swelling the next day.
Unfortunately, I don't remember the gentleman's name and even though, I witnessed the accident, someone else who was there may be able to give better details.
>Well, I almost made the unjury database today. I had just put a chunk of BLM burl on the lathe. I pulled the on putton and at the same time bumped the speed control knob. It sure is amazing how fast a lathe can spen a chunk of wood.
No injury to and I sure am glad I installed the remote switch. Then the lathe started to lift off I hit the remote switch as I was headed to the door. If you do not have a remote switch on your lathe you should move the power plug as far away from the headstock toward the tailstock as you can. That way you will not have to cross in front of a flying chunk of wood to kill the lathe.
