Sandblasting Unit....
Wally Dickerman in Arizona
>I'd like some feedback on small benchtop sandblasting units. Any help would be appreciated.
Wally
PS..ARIZONA CARDINALS ARE GOING TO THE SUPERBOWL!!
Wally
Re: Sandblasting Unit....
>Wally,
What will you use it for?
I have three kinds of small sand blasters. One is simply a can like a paint sprayer and is good for small things; provides a lot of control. The second is a nozzle connected to a tube you stuff into a supply of sand. Works OK, extremely inexpensive (HD). Both of these need a cardboard box or something to contain the sand, best done outdoors.
My favorite for very small things and glass blasting is a home-made hopper with a nozzle at the bottom shooting straight up. You press the object against a hole in the foam rubber cover. All the grit is recirculated and contained within the hopper so it can be operated anywhere. Great for sparkplugs too. I have details for making one.
Are you considering a small enclosed booth?
>Yes, I plan on a completely enclosed unit, to be used indoors. I've seen such units but I've had no experience with them. I plan to use it on small HF's mostly. There are some out there that aren't very expensive but I don't know about quality. I also know very little about the blasting materials. Seems like woodturning is always a learning experience.
Wally
Ed Heuslein
>Howdy Wally: Timely question. I just finished sandblasting two ash bowls, one about 8" and one about 15". I have a cab't I purchased at Tractor Supply (may be local to East Texas, I don't know). I looked at every type I could, including Harbor Freight (don't like them). The one I got is made in the USA by Clarke.
Now, for my opinions. The biggest problem I have is is seeing the bowl as I'm blasting. At first, I see it just fine. But, as the viewing area gets blasted also, the bowl just ends up being view behind a matte blasted piece of plastic and hard to see. Also, the air pressure going into the cab't must leave the cab't. This is done via an opening with a small filter on it. The filter clogs up quickly. A real PITA. But, I've blasted about 5 hours in the past several days (you need a good sized air compressor also - at least 60 gal.) and to decent results, depending on what you wish to accomplish.
Media is my downfall. What I'm doing requires a large sharp grit media and I haven't been able to find it locally.
Perhaps you've seen some of the Western Cedar, Douglas Fir, Green Ash, etc., pieces some have blasted all the way through in the soft ring areas. Bill Luce comes to mind and he is just darned good.
One last thing. Having the cab't means you can re-use media over and over 'till it gets dull. Without the cab't, you spray it once and it's gone.
Just my $.02. Hope it helps.
John Jordan
>Wally,
Got to TPTools.com. It's a great resource on what you need to know. If you are trying to save a nickel, the Harbor Freight cabinets are often on sale, but the TP guns etc work better.Fine glass beads are good for fairly light/subtle effects. Aluminum oxide in fine grit is pretty aggressive in wood. I use low air pressure 60-70 psi usually. Start low and go up until you like what you get. I put a filter and reg right on my cabinet. I use it a lot for my motorcycle stuff.
I cheered for your Cardinals today, and will in the SB. I don't like the Steelers and HATE the Ravens. I can't believe it's not the Titans playing the Cards.
John
Big Compressor
>Wally
I just went through this recently, there are many inexpensive units out there, and the problem I found is that you must have a big compressor, something like a 3 hp unit able to move 15 cf/min.
I am blasting and old granite chimney and the 2hp 5.5 cf/min is very marginal.
I know your work is smaller, but something to keep in mind.
Jorge
Re: Sandblasting Unit.... *LINK*
Mike from St. Clair Shores
>Wally,
I have been exploring this idea for quite some time. I found a pen size sandblaster at a site called scmsysteminc.com. It has a lot of info on the site. I will try to add the URL below. There are videos to watch and a lot more. It is also fairly pricey. Good luck.
Mike
SCM systems
Thanks For Your Help Folks....
>Thanks John....I'll check 'em out.
The football game looked like a shoo-in but in the second half it turned out to be a heck of a game.
See you at Mesa again?
Wally
rental
GolfSteve in Calgary
>Hi Wally,
I'm lucky and have access to sandblasters at work. A full size sandblaster is nice to have (the compressor for ours is must be run by a 200 hp gasoline engine), but scary to use. We also have a tiny automotive bodywork type sandblaster that is just right for woodworking, but it needs more compressor than I have at home (I have a 3 hp, 10.5 ft3/min compressor).
However, when I was looking for info on a piece of sandblasted glass for my nephew, I ran across an ad. in the yellow pages for an outfit that has 12 sandblasting booths set-up and available for rent by the hour. You could pick your media (sand, walnut shells, glass beads, etc). I never found out the cost, but if a similar service is available in your area it may be worth checking out. Try looking in the yellow pages under glass, under automotive bodywork (eg. glass blasting of air intakes, etc), under sandblasting, etc.
Steven
Fog Tanner
>Wally,
Can't help you too much with a benchtop model. My daughter just bought a standalone cabinet model from Harbor Freight. She was going to get one from Wholesale Tool, but HF ran a sale that was too good to pass up. This model has a light, which you have to have, and siphon gun. It wasn't that much more than the bench top models.
We found that we needed a cheap shop vac hooked up to the cabinet if you want to see much of anything. This model has a hook up for a shop vac and a ducted fresh air supply. The cabinet needs to have a vent of some sort, or it will presurize and you get dust from every seam.
For cleaning glass (she is a glass artist), the siphon gun works OK. I just got through spending several hours with it. I have also tried some of the different media (aluminum oxide and garnet) on some various woods with interesting results. The garnet is more aggressive on wood it seems and just the opposite on glass.
You need some volume of air to run this thing if you use the coarser grits and larger nozzels. I have a 60 gallon tank and can keep the compressor running if I stay on the gun. We are looking at a pressure blaster to try to reduce the air consumtion. We tried the Harbor Freight version but it went back this morning - had too many quality issues for the money.
An alternative to buying one is make your own. The gloves can be had from Wholesale Tool and you can make a plywood cabinet (box). Trent Bosch made his own from plywood and would be a good source of information on that.
Fog
