stall mats
stall mats
stall mats
>Someone mentioned using stall mats for cushioning in front of the lathe.
While I do not personally recommend them for shop use (they are too hard for my feet), those who like them may want to know that Tractor Supply just dropped the price yesterday. All the local stores have the same price change so perhaps it is nationwide. The new price is $37.99 each, $10 cheaper than our farmer's co-op. These mats are 4' x 6' x 3/4", hard black rubber from recycled automobile tires, diagonal grooves on the bottom.
I bought a whole pallet today (25 mats) which drops the price to $34.99 each, but you'd have to have a lot of lathes to use that many! (At over 2000 lb I'm glad I have a heavy-duty truck.)
Re: stall mats
Re: stall mats
bill Crommett
>They may be hard, but it sounds like it would beat a cold concrete floor.
Re: stall mats
Re: stall mats
robo hippy
>I was talking to some one at a local place that sells mats, and was told that stall mats work fine if you weigh the same as a horse. Softer ones work better for us. I do guess that it would be better than the concrete though.
robo hippy
Re: stall mats
metal lathe matt's ?
>What kind of matt's should you use around a metal lathe. The shaving get stuck in the 2 that I have tried so far. Would a wooden platform better. Wood will warp due to the moisture underneath. Could I cut grooves in the underside to help it breath and maybe stay flat or is there a better method. I can't really raise the platform more than about an inch or it would be uncomfortable to work on the lathe. I could use 1/2" ply and make sort of a torsion box frame underneath but it would be pretty thin and I don't know how much stiffness it would add.
Re: stall mats
Re: metal lathe matt's ?
TomCollins
>John, my experience with wood surfaces and metal shavings is that the shavings embed themselves into the wood surface and become almost impossible to remove unless you pick each one out. Metal shavings and mats are a real challenge since the shavings are so sharp they dig into everything.
I have a piece of old pickup truck bed liner I cut to fit in front of one of my work benches. The consistancy is similar to the stall mats. While I don't do a lot of metal work the shavings I do generate seem to clean up off this mat well.
My uncle had a dog that would eat metal shavings! Did that for years without any apparent side affects. Probably not a good solution.
TC
Re: stall mats
>My dog will eat most anything but I don't think she's tried metal shaving yet.
I had not thought about something kind of hard on top of a soft matt. That might give me some foot comfort and still be cleanable.
Re: stall mats
Roger in MO
Roger in MO
>John, you could "bread board" some 1x2 or 1x3 spaced about 1/2" apart to make a platform. That's what we used in one machine shop except we made a "panel" since height was not an issue.
Roger in MO
Re: stall mats
Re: Think "Disposable"
Mike Jones, Redding, CA
>I think that I would pick up some used carpeting and sponge pad. Cut to fit you work area and just throw it out (replace) it when it get too ugly!
Re: stall mats
>Carpet will catch spiral metal shavings and make a big mess. I think I'd try something like linoleum that I could sweep up easily. The stall mats might be better than the spongy mats in this case even if they are not as easy on the feet.
Re: stall mats
Gary Evans Tallassee, TN
>Hi John,
I haven't done a side by side comparison, but the mat in front of the metal lathe and all the other machine tools where I'm working now is very similar to the horse stall mats that are sold at Tractor Supply. Steel and aluminum shavings sweep up easily.
If you are interested I'll find out where they were purchased.
Gary
Re: stall mats
j
>We use the rubber mats the WoodCraft 3x10 in front of our mills and lathes with no problems. We also sweep with a stiff broom.
Re: stall mats
>John I'm thinking Linoleum glued to a soft sponge matt. That might give me both shop resistance and softer than the concrete.
Re: stall mats
>I'll check those out. We have a tractor supply in our town. I don't know if it will be open tomorrow but I'll check and see.
Re: stall mats
Re: stall mats *LINK*
Michael Stafford
>I have these mats in my shop. They are about 3/4" thick and are comfortable to stand on. They interlock together so you can put them in any configuration you desire. They can be cut with scissors so that you can notch them around the feet of your lathe. They are light so it is easy to move them and you can sweep or vacuum chips right off of them.
About $10....
Shop Floor Mats
Re: stall mats
Re: stall mats
>Mike I have about 8 of those and like them for my woodworking machines. The metal chips stick right through them
Re: stall mats
Re: stall mats
Michael Stafford
>Oh well, I had no idea John. Sorry. They work well for cushioning the feet and wood chips don't stick. I don't have any other ideas. They do make plastic grating but it would be uncomfortable to stand on for a long number of hours.
Re: stall mats
Jarrad
>You might try this; take a cut to desired size 1/2" plywood and glue some 8 or 10 pound carpet padding to it. Put the pad side down and the metal shavings will not affect the padding. Also you could lay (if you can find them) large magnets on floor in front of you, then just clean the magnets off. Just a suggestion.
Re: stall mats
bill Crommett
>John : If you are worried about moisture warping any wood platform, just glue down some shower pan vinyl under the wood. When I built this house, I put down a one inch layer of blue board covered with 4 mil polyethylene. Boy, did the concrete finishers bitch and complain ! But I have a dry basement floor.
