Question On CA Glue, not Turning related
>Does CA have a temperature limit? I am working on a family owned home and I need to glue some plugs into holes that the screws have wallowed out. (The screws hold the strike plate into the jamb on an exterior door and I want to drill the holes out and install a plug and then reinstall the plate/screws) Its cold here, single digits, and I don't think this is a good time to use yellow glue. Would CA work?
(I asked this here because turners use a lot of CA)
Re: Question On CA Glue, not Turning related
Dave Anderson (PacNW)
>I would use 5 minute epoxy. It is the only gue with stuctural gap filling capabilities
arkie
>Not at that temp, but I have fixed similar problems using matchsticks dipped in white glue. Jam them into the hole, cut off flush. Pack the hole full, and drive the screw in while the glue's still wet. This works if the hole's not too badly wallowed out, and it's a lot quicker.
Harry In beautiful downtown Kulpsville
>Lee Valley has a great gizmo (technical term) for this sort of thing. It is a tapered reamer with the same taper as a pencil. Simply ream out the hole to match the reamer and then glue in a dowel that has a point made with a pencil sharpener. When the glue is dry, cut the dowel flush with the edge of the door or jamb.
Re: Question On CA Glue, not Turning related *LINK*
Curly Smith
>From the link:
"Be sure to keep in mind that cured cyanoacrylates are generally thought to have a useful temperature range from -65�F (-54�C) to 180�F (82�C). This compares to a useful temperature upper limit for most epoxies of 200� F (93� C)."
so you'll need a lot more global warming to reach the lower limit.
Super Glue-3� Cyanoacrylate Based Glue system
you can use fairy dust
>Barry,
I don't think the glue matters much. I've repaired numerous doors with no glue and the fix has always been permanent. I whittle a spike from a hard, tough wood (usually oak), drive it into the enlarged hole, and break or chisel it off at the surface. I make a tiny starting hole for the screw. The force of the screw threads forces the plug fibers into the casing and holds very tightly even without glue.
Most of the casings are soft pine, so I think the oak helps prevent future loosening.
Based on this, yes, CA glue will work fine. So will yellow glue. A kiddie glue stick should also work.
