100 year old walnut? hard as stone?
>I've been cutting up a long 3.5" x 10" walnut slab on the bandsaw. At least I think it's walnut although I was told it was something else. One end is beautifully figured. The slab is so heavy I can barely lift a 6' section.
The reasons I think it's walnut: under the microscope a transverse section looks like walnut from the pore and ray structure, tyloses and all. The tangential macro surface looks like walnut. It has a chambered pith, a distinctive attribute of walnut. It clogs my sinuses exactly like walnut although it doesn't have much smell. It's certainly the right color. The density is a little on the heavy side for the walnut I'm used to: 42.6 lb/sq ft, although within the accepted range. However, I don't think it is good ol' TN black walnut - heavier and a little finer grained.
I was told it was used as a fireplace mantle since perhaps the late 1800s, possibly originating from California. I wish I knew the history - I found one lead bullet embedded, probably after the wood was partially dry based on the discoloration.
To the point: this thing is hard as rock! I made perhaps six ripping and four crossection cuts on a 24" section of the slab and now a brand new 1" Starrett bimetal blade is too dull to cut anything. How is this possible? Does any kind of walnut contain a high percentage of silica? Does very old walnut get hard enough to quickly dull bimetal blades?
