>I have got to get some kind of sharpening system. After years of hand sharpening I am getting frustrated. Whatever I get must be able to handle gouges, skews, scrapers,etc. I am looking at the wolverine system and would like some input on how easy it is to use and how effective it is. Also, I would like help on the best stones and what grits to use. I have a good baldor 2 wheel grinder, 3450 rpm.
I also just saw something new to me- the Work sharp 3000 in the woodcraft catalog. I am not real sure how it works. It is also about $50 more than the worverine but if it offers any advantages I could accept the higher price. Anyone have any experience with this one. I would appreciate any opinions, advice or comments anyone may have.
>I have the Wolverine system and it works well for me. The only part I don't like is the skew chisel jig. Maybe I'm a klutz but I do better with skews on the flat tool rest.
Also go to the Oneway site and download their sharpening video. (If you have a slow speed connection, they will send you a copy) The video covers all you want to know to get started doing repeatable sharpening.
Your Baldor grinder should be fine. Unlike a lot of others, Oneway recommends sharpening at 3450 rpm.
>...because they sell replacement tools when you grind yours away! The Wolverine is the standard in the turning world and would serve you well, regardless of what speed you use.
>I have the Wolverine and find it is the only thing I need. No other stones or hones. The ability to get exact resharpenings is the beauty of the system to me. I second the recommendation about getting the video. I just watched again today and saw some things I want to try.
>I have the Wolverine with the Vari-grind jig. I use it for sharpening most of my turning tools. I have a set of water stones (250 - 8000 grit) that I use to sharpen my skews, flat chisels and plane blades.
I use both the wolverine on a slow speed Woodcraft grinder (norton 3x K in 46 and 80 grits) with the flat tool rest and with the gouge jig. I don't like the skew chisel jig so I grind them with the flat rest or use a Tormek. I use the wolverine for initial shaping and quick touchup for several tools.
The diamond point dresser that Bill Grumbine sells keeps the wheel in good condition.
For finer sharpening, nothing beats the slow speed Tormek water wheel. It is worthless for grinding a new shape on a gouge, skew, or scraper. However, it's quite quick to set up and refresh a gouge and the edge, is unbeatable. Since it removes only the smallest amount of material, tools can last far longer than if sharpened with a normal grinder, especially if done by hand. The Tormek is expensive and it does take a few minutes to set up - you have to pour water into the container and wait while it soaks into the wheel. I usually set up and sharpen most of my tools at once. Since I keep several of the same kind of spindle gouge, for example, and use a diamaond hone between sharpenings, I don't need to sharpen very often.
If you want to read past discussions on this same subject, search the archives here. A quick search for Norton turned up these threads, but there is far more:
>I love the Wolverine system, except for the skew sharpening guide. I built an addition to my flat table for that. I only use that for the occasional rough grind. I sharpen the skew mostly with diamond hones and a leather strop.
According to several people who are much sharper than I, the correct speed for sharpening HSS is 3450. I still prefer the slower speed. I just feel it's safer. My tools still get just as sharp and it still only takes me a few seconds to sharpen them.
>I have the Tru-grind jig which is very similar to the wolverine but takes less space. I also use Alan Lacer's diamond honor to keep the edge extra sharp.
>I have strong opinions on this. The standard in the woodturning world is the wolverine. BUT!!!! If I had to start over again I would put together a highbred system. The Wolverine base/sliding arm is best cause I can use my bevel angle adjustment blocks and change my grind between a bowl gouge and spindle gouge without moving the sliding basket or jig arm.
The TruGrind by Woodcut is the best grinding jig arm to use because the Wolverine will drive you crazy keeping the metal flap that holds the gouge in the jig from dulling the tools as they are removed from the jig. The TruGrind jig is better engineered for what we want to do. So split the order up from two companies and you have a superior product and the cost will be the same as if you got just one system.
I dont like the Tormek type sharpening systems. They are too slow and I cant get the side angle grind I want.
Slow speed grinders are easier to learn on, but once you get the hang of it the fast speed will do you fine.
>Jim, Craft Supplies is clearing out their McNaughton sharpening systems. Besides the clearance pricing, McNaughton has a couple of advantages worth nothing. Their table has a notch to surround the wheel. Makes sharpening the sides of scrapers safer. Also, the front corners of the table are rounded off. When you swing the tool from side to side, the ferrule won't hit the corners of the table like the Wolverine.
The gouge jig works like the tru grind and wolverine. It does not have the metal flap that Lyle mentions.
>I thought I saw an ad somewhere showing a newly designed Volverine jig that doesn't have the flap. In any case I never realized that it is dulling my tools; I would be surprised that it does.
>... a ball bearing on the end of the screw shaft, but don't recall if it was a retrofit. That spring flap on the original jig only hits the cutting edges of a gouge if it is incorrectly bent down.
>Ever since I saw Lyle talk about this I've been playing and watching mine. I don't really think it's an issue. The metal might actually rub the very first part as you pull it out but my edges cut well and the way I pull the gouge out it doesn't seem to touch the edge.
>OK, everyone go out to your shop and turn the Wolverine jig upside down and look at the black metal flap. Is it still black?? No, see where the paint is worn off. Ive seen some that have worn a slot or hole right through the metal flap. OK, what has scraped off all that paint?? Your sharp edge, right?? Is your edge sharp after scraping it accross the metal plate?? Not as sharp as it should be. Lyle
>Not from rubbing on the sharp edge but from rubbing on the edges of the flute! I find it quite easy and instinctive to use my left thumb to push up on that spring when withdrawing the gouge. I think this is a non-issue!
>Harry, It is a big issue for most. You have figured it out and solved the problem by lifting the spring flap off your sharp edge. Most have never realized it is a problem. I have seen hundreds of turners all over the country dulling their tools on the wolvering jig. You figured it out, should we share your awarness with the rest of the turning world?? lyle
