Re: Serenity Now. Serenity Now.
Bill Grumbine - Kutztown PA
>Oh my, what a discussion we have going on here! I used to have that tool beat me up all the time, but once I got it figured out, I only get beat up half the time. ;-) Seriously though, once the thing is set up properly, there are only a few other items to observe to get a nice core without all the stress involved.
Make sure the tool tip is on center, with the top of the knife against the gate. If this is not observed, it does not matter how strong you are. If it is observed, it does not matter how frail you are, if you at least have the strength to stand and hold the weight of the knife. I have had little old ladies get successful cores in my shop.
Widen the kerf at the top if you need to do so. Sometimes the knife will bind in the kerf as it gets further in, and that will squeal the belt. Move the tool rest in towards the center just a hair, and widen the kerf. I have done this with the lathe running! But it is a good idea to stop it first, at least until you get the hang of it. Along with this, back the knife out to clear shavings often. Clearing the shavings keeps the knife from binding in the kerf.
I core at pretty high speeds, usually between 700 and 900 rpm, and mostly at the higher end of that range. This is especially true of natural edged pieces, where I don't want a sudden jump in the knife to dismount the piece or shear the tenon off. I also regularly core bowls with a tenon that is 25% of the total diameter. If they are tall, I will use a steady rest to help keep them from breaking off at the tenon.
If the knife is cutting smoothly, don't stop! Keep it going. A lot of problems arise on reentry into the kerf, especially if you hit the core where it starts to cut again too fast. It causes a catch and often dismounts the bowl with varying degrees of damage to the tenon. And remember, the closer you get to the center, the slower the wood is moving, so you have to slow your feed rate down or speed up the lathe.
With all this, I can safely say that there is not a lathe out there that I have not stalled with this tool. Most of the time it works like an extension of my arm, but every now and then, it gives me fits. I have a short section on my second DVD that deals with the basic usage of this tool, but if you want to see a comprehensive treatment, Robohippy, aka Reed Gray has a full length DVD that I think is exceptionally well done for the content on how to use this tool effectively.
If anyone has specific questions to direct to me, I will be glad to try and answer them.
Bill
