Bottle stoppers
Bottle stoppers
Roger in MO
Bottle stoppers
Roger in MO
>I'm looking for information on turning bottle stoppers. From the archives I found a reference to Dominic's shop built bottle stopper check but could not locate it.
What is the thread size on Ruth Niles' stoppers?
Where can they be ordered?
Thanks for your help.
Roger in MO
Re: Bottle stoppers
Re: Bottle stoppers *LINK*
Ron McKinley
>Here's the way I turn them using a pin chuck. If you or a friend can work with metal they're easy to make from a 3/8" drill rod. File or cut away 1/8" of the rod and use a 1/8" metal dowel (available from Enco or other sources)to lock it in place.
Pin chucks are available from Packard Woodworks also......Ron
Turn Bottle Stoppers With Pin Chuck
Re: Bottle stoppers
Re: Bottle stoppers
Molly Winton
>Ruth has all the information you're looking for on her website. She has all the specs on her stoppers, as well as a tutorial for turning them. You can't go wrong with her products!
Re: Bottle stoppers
Oops--www.torne-lignum.com
Molly Winton
Re: Bottle stoppers
GalenV
>I started with a set from Penn State Industries as you could get 10 the chrome stoppers,10 wood blanks, a lathe chuck and dril bit all for $55.
The materials were all good except the drill bit they provided was poorly manufactured and cut too large a pilot hole. They sent me a new drill bit and all was fine.
You have to specify the thread of your lathe spindle to get the right lathe chuck as there is a catlog number for either set.
http://www.penstateind.com
Re: Bottle stoppers
Re: Bottle stoppers
Texian
>Roger,
You can cut the head off a 3/8-16 bolt (hex cap screw) to make a mandrel, which is held in your chuck the same way a woodworm screw would be. Drill the blank 23/64" (IIRC) and screw onto the mandrel. I prefer to tap the hole before screwing onto mandrel. Or you can buy a mandrel from Ruth. Her stoppers are the best.
Re: Bottle stoppers
Ditto on Ruth
Jim Shaver - Oakville, Ont
Re: Bottle stoppers
Re: Bottle stoppers
Barbara Gill, Remlik VA
>I bought one of Ruth's mandrel this summer and absolutely love it. You can use it in a chuck or just directly in the headstock.
Re: Bottle stoppers
Re: Hint on home made arbor
Russ Fairfield
>If you make an turning arbor for a bottle-stopper by cutting the head off of a 3/8" bolt -
Cut a couple long opposing notches across 4 or 5 threads on the end of the bolt with the corner of a file. The bolt will then be like a tap, and it will screw into the wood easier. It will now cut into the wood rather than have to crush the wood to make the threads.
Try this on the 1st couple threads of the screw in a screw-chuck or a "wood worm" screw. It makes threading it into the wood a lot easier, it holds the same, and it doesn't damage the screw.
Re: Bottle stoppers
I bought a mandrel and ...
Ed Moore in SW Virginia
>it wasn't machined accurately, so it doesn't run true. Ruth's a sweetie, but the mandrel wasn't.
I think a bolt filed like Russ suggests would be a better bet.
Ed
Re: Bottle stoppers
Re: Bottle stoppers
>In addition to using a purchased mandrel, pin chuck, or bolt, you can turn stoppers with no more than a standard 4-jaw chuck or jam chuck. (see picture below) I use the Niles hardware with a 3/8" shaft, held with epoxy.
Turn the bottom to fit the hardware then the top. This method does require finishing the very top by hand, but you can also part off the top and reverse and jam it onto a short tenon cut on the waste, exactly as you would finish the bottom of a turned box.
Re: Bottle stoppers
There are two design elements ...
>to keep in mind when making a bottle stopper.
1. It should be easy to grab when pulling it out.
2. The top should be blunt so that you can use the heel of the hand to put the stopper back in.
Ed
Re: Bottle stoppers
Roger in MO
Re: Bottle stoppers
Roger in MO
>Thanks to all who responded. A wealth of information. I believe it was Ruth's tutorial that I was trying to find reference to in the archives. Your responses are appreciated.
Roger in MO
Re: Bottle stoppers
There is one design element
This has been discussed here before.
With the Niles stopper hardware this functional suggestion is considered unnecessary. The stopper seals easily with two fingers.
It is certainly a good idea when using cheap corks and perhaps some other hardware that is difficult to insert and seal.
Re: Bottle stoppers
The two design elements are not ...
>my ideas. They were told to me recently by a professional woodturner who sells lots of stoppers. I think I've made four stoppers so far.
Ed
Re: Bottle stoppers
Re: I bought a mandrel and ...oh, Ed...
Ruth Niles
>Why didn't you tell me the mandrel didn't run true???? You know I would send a replacement. BestWood Tools makes the mandrels, Victor designed them, and he is very fussy about percision. I'll send you a replacement today.
Re: Bottle stoppers
Re: Hint on home made arbor...wonderful
Ruth Niles
>That's a great hint, Russ, it eliminates one step and I'm all for eliminating extra steps! I'm going to be very honest and admit that I use my wood with the bolt (pics on my website) more often than my new mandrel. I have at least 8 of the wood ones and, for production turning, it's just easier for me.
I believe whatever way you are used to doing something and get the results you like, that is the Best way to do it!
Re: Bottle stoppers
Like I said, Ruth's a sweetie! Some ...
>things change with the weather, but Ruth is ALWAYS a sweetie.
And I thank Ruth for the private email.
Ed
Re: Bottle stoppers
Here's my arbor
>This one is made from a chunk of a recycled plastic 4x4 porch post with a through bolt. The hickory bezel covers up a standard 3/8"-16 nut. I drill and tap the blank and then thread it onto the bolt to turn it. The only trouble I have had was during roughing out the blank. The force of the gouge whacking the corners of the blank overtightened the bolt in the tapped hole and pulled out all the wood threads. I guess it would be better to actually tap the hole with the modified bolt to get a slightly tighter fit.
