index wheel for Jet 1236
Roger in MO
Roger in MO
>Looking at the manual for the 1236, I can't see any way to mount an index wheel (or a hand wheel) on the outboard end. Am I missing somethng? (It's the older blue model)
Is there any reason I can't mount an index wheel behind the chuck? Thread length looks sufficient.
I have the article by John Lucas from the archives. I plan on using 1/4" plexiglass and drill holes for the indexing.
I'll appreciate your comments pro and con. Thanks
Roger in MO
Re: index wheel for Jet 1236
Texian
>Not familiar with your lathe, but I have used an index wheel mounted on the spindle behind the chuck. In my case it was a degree wheel, so I had to rig a pointer and a friction brake to hold the spindle at each selected point.
Dick Hines
Dick Hines
>Check out Alisan Engineering. I got a few months ago for my Pm 3520. Works good and can be installed behind the chuck when needed.
>Roger I usually mount my index wheel between the chuck and lathe spindle. I have rigged up an index wheel on the outboard side of a Jet mini lathe. It's been so long since I've seen a Jet 1236 I can't remember how the outboard side looks. Some lathes simply won't take an index wheel on the outboard side. Inboard works just fine.
don lewonczyk
>I bought one from Alisan ( the universal one that fits on many lathes from 10" to 26" I think./ Since my spindle shaft is 1-1/4" thats the size I got but put a reducing bushing in it to fit my mini lathe, works great also the mounting configurations that you can use with it. The company also makes parts for ornamental MFD turning, the you make it Rose Engine. Not selling anything just putting out info. Take Care. DonL
Roger in MO
Thanks for the responses. NM
Roger in MO
David Walser
>Does anyone have a link for Alisan? I tried Mr. Google and came up empty.
Dick Hines
Re: Thanks for the responses. NM
Dick Hines
>I hit the n instead of the m.
www.alisam.com
