fatigue mat?
Bob Ingram
>DO you use a fatgue mat?
What Type? Spongey or hard rubber?
I am needing to get some mats for the lathe area
I am looking at a 4' X 8" stall mat from Tractor Supply at less than $50.oo
What is your opinion
fatigue mat?
Bob Ingram
Re:I've been using stall mats made ......
Jamie D
>...from recycled tires for years, and I assume that's what you're seeing at Tractor Supply. They are indestructable and comfortable, but the hard part is cutting them into 2 pieces for 2 lathes! I had to finally use a skillsaw with a course blade, and they definitely don't walk around the shop.
Karen
>I'm SO glad to read this tonight because MBH and I were just discussing this over supper.
Looks like we WILL be taking that trip to Tractor Supply tomorrow.
Re: fatigue mat?
>I use spongy mats at the lathe and bandsaw. I got some from Woodcraft a few years back and found another elsewhere. Mine are 2'x3' and 2'x5'. I do know I can stand at the lathe for hours with no problem where I was miserable without a mat.
I've bought a bunch of stall mats for the horses (I believe the standard size is 4'x6', at least around here) but try to find them on sale. The last time I bought some I got 10 at the farmer's co-op for $35 each. I need to get another 25 or so for the new barn. MAN are those things heavy - it takes two of us to slide them around in the mud! I put them outside the barn as well at the doors and feeding areas.
I think the stall mats are much too hard for foot care in the shop. They would be excellent, however, to protect lathe tools from edge down contact with the concrete floor and for a little insulation. A big one could even go under the lathe, but I'd still put a spongy one on top.
Iturra Design has one in their catalog that was expensive but touted as the best in the world. 866-883-8064 I haven't tried that.
>Jamie, I cut them with a utility knife and a straight edge. After the first cut, I slip a 2x4 underneath to bend slightly and spread the rubber for the next cuts.
But my feet must be in worse shape than yours and need softer mats.
Re: fatigue mat?
John Veerkamp, Western Mo
>I've been using a stall mat at my lathe for several years now. It may seem hard , but it is much easier on the legs than concrete. Go for it.
Re: fatigue mat?
Jim Sebring
>Sears has run several sales over the last few months for the 'jigsaw' type of mats that have ~2 ft. square sections. On sale they're $10 per set of 6 pieces. I used double-sided tape on the ones I put in front of my lathe to keep them from moving. The stuff is about 3/8 inch thick and readily cut to shape with a utility knife. They're very comfortable for extended time at the lathe.
Fatigue mat? - Made mine from wood
Fog Tanner
>I use wood. The spindle height on my Vic is a little higher than I like, and since it is the Aussie version I can't lower the lathe so raising me was the only way. I used the 2"x12"s that comprised to shipping pallet fastened to three 1"x4"s running at 90 degrees to make a 3'x6'x2 1/4" platform. It rasied me up the 2" I wanted and is much easier on my feet than the concrete. The price was right since all the wood came as the shipping crate.
There are days when I am in front of the lathe for 13-14 hours and there is no way I could stand on concrete that long and walk the next day. Before the wood, I used some floor runner material I got from Home Despot. It comes 2' wide by what ever length you want, its sold by the foot. That worked OK and I have it in front of my table saw, but the wood has been much better.
Fog
Re: fatigue mat?
>I have one in front of the lathe, the table saw and my work bench. They are the spongy kind.
Re: fatigue mat?
John Foschaar
>I purchased my mats at Home Depot, they are soft foam sold by the foot and are about 30" wide. I have one in front of my lathe and one 8 footer in front of my work bench. Sure beats standing on bare concrete.
Re: fatigue mat?
Bill Blasic
>I use these mats from Sam's club that hook together like a jigsaw puzzle. They are on the soft side and are easy to mve when serious cleanup is needed and you can make them virtualy any size.
Re: fatigue mat?
don lewonczyk
>I bought some from a fabric shop going out of business soft on the bottom slightly ribbed black rubber on top and tapered all the way around so you can sweep up and over the mat and don't have to move it. I also use the mats at the craft shows makes the difference of your feet crying at the end of the day or smiling. I have a few heavy ones came out of a machine shop with holes in them when you step on them the rubber is able to move under you, it gives where you are standing but they are hard to keep clean, I have a mat in front of every machine and wouldn't be without one. Any kind is better then no kind. Get a couple and make your wife something nice for being good to you. DonL
Re: Fatigue mat? - Made mine from wood
Ruth Niles
>I made a wood platform, too, and it works great. I have a fatigue mat my son gave me quite a while ago that I use in front of the mini but the wood it just as good and that's used more often at the General.
Horse Stall mats work great!
Dominic in Bucks County PA
>I have that exact type at my lathe. They work great! I had those spongey kind of mats around my shop. But I had to use (2) of them on top of one another to equal the performance of a horse stall mat.
Horse/Cow Stall mats are tough, durable, and since they're heavy they won't get sucked up by the shop vac during clean up time. They are also a great value.
They also insulate your feet from the cold during the winter. Which is really a BIG plus in my book.
When I DON'T work on the mat, I can really feel it.
Re: fatigue mat?
>I'm a fan of the ones that Woodcraft is now selling. They are soft enough to be comfortable and easy to move. They don't slip around like the puzzle ones I bought from Walmart. I have about 5 varieties of mats because I've bought them through the years and like the Woodcraft the best.
They don't work well at the metal lathe. They are too soft for that and all the shavings embed into them. I am going to look at the stall mats for that machine.
Re: I wear mine on my feet......
Jesper, Denmark
>Wooden clogs. The come in PU as well.
Mats of any kind tend to make clean-up more difficult and only work where they are.
The clogs follow me all over the shop. Warm and comfy too.
Re: fatigue mat?
Don at Central Illinois
>I hate to be a stickler for detail, but shouldn't these be 'anti fatigue mats?'. I get tired enough without adding something to stand on that will make me more tired. :))
Re:If you live anywhere near coal.....
Jamie D
>....mining country you can ofter find rubber conveyer belts cheap at places like flea markets. I bought a section about 25' long and didn't realize that they have steel belts inside until I started trying to cut into shorter sections. Back out came the skillsaw with a metal blade to do the job, and they are thinner than the stall mats.
Re: fatigue mat?
Carole Valentine
>I use the Woodcraft ones all over my shop...they are usually around $14 on sale and work fine for me. I put them everywhere I have to stand for periods of time or where I am likely to drop a tool (which ALWAYS lands business end down) The one at the back of my lathe has saved many gouges since I tend to set them down on the bed then knock them off. :) The one at the front makes standing nice and comfy.
Re: fatigue mat?
Ed Karch
>I built a wood floor 2" over the concrete slab. 3" layer of shaving over that is about the right height for my lathe.
Re: fatigue mat?
Jim Shaver - Oakville, Ont
>I use the same ones as You Carole,
I bought 5 or 6 and have them all over the place, love them.
Take care,
Jim
I've got both
Don in Northern Arizona
>I have both stall mats and the fit together jigsaw mats that Sam's club sells. The jigsaw ones work nicely around my bench and in front of the band saw and chopsaw. I have two stall mats, a thinner in front of the lathe, and a thick one in front of the table saw. The thick one is just about as hard as concrete. I definitely prefer the jigsaw ones for comfort. The ability to create paths and different sized mats is great too.
Don
Dick Hines
>I got some of the ugly ones from Lowe's. They are the ones that are for kids rooms. Great colors too. You get 1 blue, 1 green,1yellow and 1 red.
Re: fatigue mat?
Scott Hurley in N. VA
>Great idea - putting one behind the lathe. I also have had numerous tools fall point first off the back...
Scott
tools rolling off the lathe bed
Carole,
I've seen so many people do the same thing, including me.
I made something which fixed that. I spent 20 minutes and came up with a little tray that slips into the gap in the lathe bed. I used a scrap piece of 3/4" plywood, and with some wooden strips on the sides and a little carpet it keeps my working set of tools handy and they simply can't roll off. The block on the bottom is not snug. No way it can tip. Can't work without it now.
