THE WOODRAT IS BACK!
Pictures of the new shop
Roger Smith
>I wanted to share pictures from my new shop.
This is a shot of the ground preped for the slab. The tree to the right is a large pecan with a burl about 20 foot high. There is a large oak tree to the left,.
Re: Pictures of the new shop
Pouring the slab.
Roger Smith
Slab read for the framing crew
Roger Smith
Re: Slab read for the framing crew
Paul Zerjay
>What are the dimensions?
Rain halted the framing
Roger Smith
Framed and siding
Roger Smith
>The framing and OSB panels are completed. The siding is about 50% completed.
Area for noisy equipment
Roger Smith
>This is a shot of the 6 by 10 foot enclosed lean-to to housed the air compress, dust collector and vacuum. The dimisions of the building is 24 by 48.
Insulation
Roger Smith
>R-13 insulation is being blown in the walls. The DC room is being insulated in this shot. The ceilng will get R-19.
Painted
Roger Smith
>A shot of the the south interior after the walls, ceiling and floor has been painted. The ceiling is actual the same color as the lower part of the wall. By the way I hate extension cords.
Moved
Roger Smith
>Moving day was November 11, 2008. It will take some time to straighten this out. There are 10 lights fixtures containing 4 T-8 bulbs each. The fixtures were installed at an angle to help streamline the DC duckwork. The lense fogged up on this shot.
Roger Smith
>The DC, air compressor and vacuum pump has been installed. The framing for the wall to separate these machines was been erected and will contain sound insulation when completed.
Roger Smith
>The lathe area. You can see some of the framing for the stub wall in the upper part of the picture. There will be a curtain hung on this wall. It will also house a dust cleaner. Yes that is a HF lathe in the foreground. It will be used at some point as a frame work for a threading machine. The lathe to the right is a Jet mini. The primary lathe is a Vega 2400 bowl lathe. There is a 10 by 10 foot room in the background to be used as gallery.
Shot of the Vega lathe
Roger Smith
>Electrical power has been ported to the Vega. The switch on the right turns on a par of flood lights in the ceiling at each end of the lathe. The switch to the left controls the vacuum pump.
Shot of the Bandsaw
Roger Smith
Re: Shot of the Bandsaw
Mac Ray
>Looking good Roger,congratulations................it was worth the move wasn't it.................
Carole Valentine
>Wow! Looks great Roger! What sort of heating and cooling are you putting in?
Roger Smith
>Mac,
Thanks, now I just need to get some cabinets and shelves built.
Roger Smith
>Right now I am using a kerosene heater. I have a used central unit purchased. I will get it installed before summer if it works..
Re: Slab ready for the framing crew
Roger Smith
>24 by 48
Wonderful!
>Floor plan, we want to see a floor plan, please. Pretty please. I'm particularly interested in seeing how others position their equipment, benches, DC, and storage relative to the doors and windows, etc. I've CADded and CADded and I'm still not entirely happy with my own plan (for 20x44).
Ennnn-VI-oussssssss. Beautiful shop space.
Eddie Pacheco; San Jose, Ca.
>Ok, now you have confirmed that no shop is large enough. Very nice! Where are you located? Do you need a shop helper?....:-)
Re: Wonderful!
Roger Smith
>John, I do not havee an actual floor plan. I will try to get something together and email to you.
All very nice - are you going to put them..
>together and email them to the Shopshots section? David will get to them sooner or later :).
Re: All very nice - are you going to put them..
don lewonczyk
>Nice, looks like you are doing everything your way and right, have fun. DonL
Re: I had the same problem.
Brian Hahn in SW Wisconsin
>When I was designing my shop, I just could not get a floor plan that I liked. I added 2' to the building's width and everything fell into place.
