How do you chuck finials
Roger in MO
>I have a stronghold chuck with #2 jaws. I'm unable to hold material less than 2" square. Are spigot jaws the preferred tool? Or is there a better solution. I like to start with 3/4 or 1 inch stock
Thanks, Roger
Roger in MO
Thanks, Roger
Re: How do you chuck finials
Dennis Yoder
>I use the spigot jaws in my stronghold for the majority of my finials. You can also turn a taper on the blank and drive it into the headstock morris taper. I also have a reducing adapter that allows me to use my smaller chuck off of the mini on my yellow monster with good results. Dennis Y
>My lathe has a No. 2 Morse taper. I have a belt sander turned upside down in a cradle. I use a stick about 3/4 up to 1" square and grind a crude taper on the end and drive it into the shaft of the lathe. I bring up the tailstock and support the end for a while. After it is trued up, you can take the tailstock out the way. Or you can loosen it a bit after the finial starts to get thin.
You can mount the piece as a spindle and turn a taper on it and even use a larger piece and turn a shoulder on it.
I find just grinding the end on it to be quick and effective. If you are turning ornaments, you can turn the drop or icicle part and the top piece out of the same stick.
Copy the taper on one of your drive spurs.
PS...
>I don't have a Stronghold chuck, but on mine, I can take the jaws off and chuck the piece directly into the slides on the chuck.
>Roger I now have a chuck and some collets that will let me chuck up a finial. Before I had that I would mount a wasteblock on a faceplate and drill a 3/8" hole in it. Then I would turn a 3/8" tenon on my finial blank while it was between centers. Then I would glue the blank onto the wasteblocke and turn it.
Dennis Barley
>I round the finial blank, turn a waste blank to fit the #2 jaws, then glue the finial blank into a recess in the waste blank. This allows the use of the full length of the finial blank. If you use a larger diameter of the finial wood for the waste block, you can make the finial base larger without wasting alot of wood, if cost is a consideration.
Re: How do you chuck finials *LINK*
charlie belden
>SuperNova 2 chuck with spigot jaws - goes down to about 3/8" diam but will hold up to
about 1" diam - or square blank.
Trick for doing long delicate finials is to start at the tip and work your way back to the tenon - leaving plenty of meat behind the delicate part you've already turned. And sand a finish as you go because you can't go back later.
chucked delicate stuff
Jim Sebring
>Great site, Charlie. It took me a while to go all the way through it. Figger I learned a few things. Thanks.
use the bare chuck
>Roger,
If the piece is small enough to fit into the hole in the center of the chuck, you can hold it without jaws. You can grab a small piece of wood with the jaw slides themselves after possibly removing the jaws from the chuck if you have a shorter piece. All the supernova chucks allow this and I've seen photos and videos of people doing it with other types of chucks. (On a Clewes video, IIRC, turning a golf tee.)
I either hold with small spigot jaws or better, turn a morse taper while the blank is held between centers. It does take more time to turn the taper but I made a little gauge from brass to make this quickly and I usually do a bunch at once.
The reason I like to use the morse taper over a chuck is it provides more working room, you don't have spinning jaws to watch out for, and it allows longer pieces to be turned on a mini lathe at demos.
Re: use the bare chuck
Dennis Barley
>John: Would you care to elaborate on the brass gauge for Morse tapers? Sounds like a great idea. Thanks.
Dennis
>Mark StLeger makes a really cool guage to make morse tapers. I simply measure the morse taper at 2 points 2" apart using a dial caliper. I transfer these sized to the piece using a parting tool and the same calipers. Then it's just a matter of cutting the taper until you connect these two dimensions. It doesn't have to be perfect because wood will compress a little to compensate.
I use the tailstock to push the wooden taper into the headstock and then I rap is with a wooden mallet to seat if further. I use the tailstock to support the piece as long as possible. I used this technique in one of my ornament classes and it worked great.
Got, thanks John. NM
Dennis Barley
>Dennis,
Easier for me to make a quick 3D model than take a picture.
I measured a morse taper in two places, about 1/2" apart. Since the drive spindles of lathes may be slightly different, I measured the largest taper diameter just where it would reach the opening in the spindle.
I cut slots in a piece of brass with the bandsaw and removed metal to make two go/no-go gauges, one for each size. I cut a little narrow and widened with a file to get smooth, accurate openings. I put a mark on the edge showing the distance between the two. Note that I relieved the opening of each side just a bit to give me a warning that the diameter is about to reach the right diameter. Also, if you use a file to widen the gauge a tiny bit just past the opening it won't grab.
To use, I hold it against the wood and cut two grooves with a parting tool, using the mark on the gauge for the separation. I then turn the taper between the two grooves (middle), extending it a bit to the right - this gives you a little room in case you cut a tiny bit too small.
As a final step (top) I relieve the central portion a bit with the parting tool. This allows the taper to fit more snugly resting on two lands. Without the relief, if the taper is not cut perfectly it may be a touch high in the middle and will not grip securely.
I haven't seen any other gauges so there may be a better way. Eventually I want to build a tool such that it peels/scrapes a perfect taper. I've designed one, I just need to try making it.
I make all of my magic wands this way and some other small things as well. There is a real advantage to gripping a slender spindle turning tightly on one end instead of between centers. For most shorter finials/ornaments/etc I prefer to grip with the chuck because I have plenty of room and I don't have to force the work tightly into the morse taper.
Re: brass gauge for Morse tapers
>Heres a cocobolo wand blank ready to go. (I slice some wood off the other end with the bandsaw to ease turning the shaft.)
When I'm making a bunch of these, it's nice to have a second lathe at hand to test each one without having to knock out the drive center each time.
BobM
>I use the #1 jaws on either a Stronghold or Talon chuck and use the live center on the tail stock on the other end. When I am finished with the icicle or finial I cut it loose on the tailstock end.
Dick Hines
>I use spigot jaws. I also use pen blanks for finials. If you are doing small ones you can rip a blank into 4 pieces. At the price of blackwood it is worth the effort.
Dennis Barley
>Thanks for the info on your gauge, John. I may have to build one.
Dennis
Roger in MO
>Many thanks for the responses. I will try some of the suggestions. Roger
Usually right after I break them (and bad words)
Steve Antonucci
