>I got this lovely Honey Locust hollow form (HF) from Bill Eliot in a holiday turning exchange a little while back. My wife wanted a table lamp, and wondered if Bill's hollow form could be used for a lamp base. The HF is 10-3/4" tall. I turned a simple round base and another collar-like element for the top of the form from local Kamani wood. The bottom disc was drilled in the center and out the side for running a power cord. The top piece looked like a thread spool with one of the ridges cut off. This was drilled to fit a short length of threaded hollow lamp rod. Standard lamp kit fittings were then able to be attached to the threaded rod. Top and bottom pieces glued to HF with 5-minute epoxy. A simple lamp shade completes the project. The overall lamp height is about 24" tall. Apologies to Bill if he is offended by this adaptation to his hollow form, but I like the end result. What do you think?
>I like it, especially when it turns out good. You took a piece of art, nice to touch, nice to look at and made it useful plus keeping the beauty of the orginal piece. Nice job.. DonL
I think the form works very well in the new application. The scale is a good balance with the 'new' base; the proportion, size, and color of the shade works well too! Well done to BOTH artists!
I also like the appreciative Phalaenopsis orchid in bloom!
>I like the lamp shape and form a lot. I have been told by a person who repairs lamps that the shade should extend down to just below the hardware. I do not have an opinion on this but would like to know what others think about shade length.
In the case of this lamp, if the shade extended below the hardware the rim of the shade might hide some of the form at normal viewing angles (while standing in the room).
