Tapping threads in homemade tools
James McClure
>John mentioned homemade tools the other day and tapping threads in them. I have made a few tools myself and find tapping to be an inconsistent process at best. My success rate is pretty good when tapping holes for 1/4" bolts, but when I try to tap smaller holes, I have problems and end up breaking the tap. I am tapping for the set screw to hold an HSS cutter. It's a #10 - 24 thread screw that holds the cutter in place. I have broken at least 3 taps and a on one of the holes that was successfully tapped, it is very hard to get the set screw in. In addition to breaking taps, I have bent the tap holder and now it doesn't hold the tap without slipping so I switched to using a cresent wrench. I am using 3 In 1 oil in the process. I have tried to tap O1 drill rod and some zinc plated cold rolled steel from HD. Any ideas???
