spear point bevel tool
Richie
>I recently purchased a old set of craftsman wood turning tools on ebay. the set came with a spear point bevel edeged tool about 1/2" wide. My question is what specific type of cut is this tool designed for?
Richie
Re: spear point bevel tool
adrien
>Possibly for trimming the foot of a bowl to get a sharp definition? Raffan suggests a tool like that.
jake Niedling
>It could be used for cutting shallow grooves in the bottom of a bowl or a shallow groove where you want to wire burn a line on a spindle turning like an ornament.
Doug Thompson near Cleveland
>If it's the same set I have that's a parting tool. Lay it up on edge and cut grooves, etc.
Re: spear point bevel tool *LINK*
Fred Holder
>That old tool was made for cutting "V" grooves in the turning. On very hard dense wood it worked well, but on softer woods it tends to tear the grain. A better tool for that purpose it the Bill Jones Point Tool or the skew chisel.
I think all of the tools in those old Craftsmen chisel sets were spindle turning tools and not designed for bowl turning.
More Woodturning Website
>Although they are generally used for making v grooves and possibly scraping with either side my best friend used it like a skew. He rubs the flat side on the wood so it acts like a bevel. He uses this tool to finish the bottoms of goblets or face off endgrain areas. The funny thing is he claims he can't use the skew but he uses this tool just like I use a skew in these applications.
Turning Tools in The Old Days.....
Wally Dickerman in Arizona
>I bought a set of Greenlee turning tools back in the 50's. It had a 1/2 inch spear point tool. All tool sets in those days were for spindle turning, and all contained a spear point tool. All were carbon steel. The spear point was designed for cutting small grooves. I think that it's interesting to note that while those sets were designed for spindle turning, half of them were scrapers.
I still have most of that set of tools. I have re-ground them for special uses. The spear point is useful for left or right-handed scraping in a tight little spot that nothing else will reach.
Wally
Re: Turning Tools in The Old Days.....
Bill Grumbine - Kutztown PA
>When I first started turning, I asked a lot of experienced turners what this tool was for. No one knew. Eventually I got together with a guy who turned using mostly scrapers. He did not educate me directly on the use of this tool, but he did teach me to grind my scrapers to a 30� angle. Once I started doing this, I discovered that they worked pretty well on a lot of spindle work. This tool does great v grooves, but it also is pretty good for rolling a bead if that is the way you want to do it.
And of course, it does a great job on bowls. I often use it for creating a dovetailed tenon.
Spear Point Scraper
Brian Hahn in SW Wisconsin
>That's a spear point scraper. It's used for making v-grooves and clean-up scraping in tight corners. It's also good for making dovetails for chucking. You can still buy spear point scrapers but they now have a steeper/shorter bevel.
>Do you mean a spear point scraper? It's the most aggressive hollowing tool I have for starting hollowing on boxes or making bell-shaped ornaments. I sometimes use it for rounding oddly shaped chunks of wood which give a bowl gouge a beating. Great for cleaning up in tight places on the outside and making little groves. I also use it for "distressed" textures such as for magic wand handles - very popular.
Distressed textures
>That's one of the best uses I've found for a skew. Just jab the point at the work and let it run wild.;))
wow! Thanks for the help.Evan got some pros to res
Richie
Re: Distressed textures
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I'm glad you asked the question because I have several of them and never use them. Now I have some ideas; but , frankly, I haven't seen any suggestions that can't be done better with a skew chisel.
Robin Corell in Atascadero CA
>A spear point scraper can also be a great tool for truing up something that is out of round and being problematic with a roughing gauge. It can also be used in this same way when doing faceplate work.
There is a patternmakers tool which is very similar to a toothing iron from a plane that is ground like a scraper and used in this same way. It basicaly becomes 30 spear points/inch and is really and interesting tool . I have used 2" square nosed toothing tools on faceplate work with no catching or twisting problems.
Robin
Re: Distressed texturesI agree
richie
GalenV
>Great Neck turning tool sets still have a 1/2" spear point chisel and Penn State Industries has a set with what they are calling a 5/8 spear scraper. Guess they cannot be too outdated if they are still selling.
Being newer to truning it is interesting to me that there are a lot of tool shapes being sold and I guess the manufactures must assume you know what they are for as very few say.
Saying that I guess I never got an instruction sheet with pliers, end wrenches, pipe wrench (must be for pipe!)and so on :-)
Guess it could get worse: goose neck pliers and channel locks.
Some things you can match: phillips screw driver to phillips head screws!
It must be late, sorry!
instruction manuals
>Galen can you imagine if an instruction manual for a pair of slip jaw pliers was written by the same guys who write manuals for computers. Then try to imagine that it was written in chinese and translated to english. No wonder our kids can't use tools.
mpax356
>I have both sets of Harbor Freights HSS turning set each of which included one of these 1/2" scrapers. In one set they call it a beveled scraper and the other set calls it a parting/bead tool. I reground one to make it a sharper point and use it for doing rings at the base of my bowls.
>Good instruction manuals for many tools are how-to books by Richard Raffan, Mike Darlow, Kieth Rowley, Michael O'Donnell, Phil Irons, Fred Holder, Ray Key and many others.
Also, manufacturers make more tools than can ever be useful to any one person. Some aren't much use to any person. I think they make some tools just because there are people like us who will buy almost anything and then try to figure out what to do with it. ("Hey Joe, we sold another one, what a bunch of idiots - ha ha ha ha!")
Re: instruction manuals
Barry Turner
>I've seen instructions that read like they were translated from Chinese to English by someone would couldn't read or write either language......
Good manuals
GalenV
>John
First book I got was Keith Rowley's new addtion on Woodturning a Foundation Course. Our public library has Raffan's books and updated DVD.
Actually watch a lot of You Tube video on turning to learn.
I will say that Jet has a few and they are done well. Good to explain tool,presentation and SLOW enough to understand with good camera angles.
Clive Brooks from Robert Sorby and Doug Thompson also were good to provide help by email as a tool manufacture.
There is this Lucas guy who just did his first video and if he cleans up the video it is done well :-)
I think the suppliers will help if I just ask.
Got very good help from local Ames area turners now as well.
Nice thing about starting turning as a hobby, good people.
Galen
Re: Good manuals
Don wilcut
>If you haven't seen him in action You will pleasantly suprised if you can get "this Lucas guy " to come and demonstrate at your club. He has a wealth of knowledge and imparts this knowledge so beginners to professional turners can enjoy and understand his presentations
good demos
>>...get "this Lucas guy " to come and demonstrate at your club
I agree. John's given several demos at our club, photography, skew chisels, inside-out turning, hand mirrors, hollow forms, and probably a few I missed and/or forgot. I learn much each time. He's within (long) driving distance of our club but fortunately lives near the middle of half of the country. IMHO your club funds would be well-spent to pay his airfare. (Don't know how to haul tools by air these days, though.)
Re: good demos
GalenV
>I am enjoying learning who the turners are and the variety of backgrounds you all may have.
Just need to be in Tennessee in mid May as I think I read John Lucus has a workshop at the Appalachian Center for Crafts at that time.
But with bad heart I cannot do long traveling.
I read an article that John lists like 25 short steps to make the hand mirrors and I thought yah in his twenty years I could maybe do that! They are art more than just a hand mirror!
Think it was after I read his article of reverse turning bowls I got the One Way Jumbo Jaws rather than try and make some of his other examples of fixtures so I could finish the foot of a bowl.
Nice to just keep learning even if I had to retire.
Hope you good folks can put up with me on Wood Central as I enjoy topics and the input and support you all give one another.
Galen
