Wood handles for Thompson lathe tools
GalenV
>I just got two Thompson lathe tools and turned hard maple handles for each. I need to bore the handles for the 1/2" V bowl gouge and 3/8" detail spindle gouge. What is the best way to secure them to the wood handles?
The 1/2" (.499) is just a tight slide fit into a 1/2" drilled hole. The 3/8" (.371) is a loose slide fit into a 3/8" hole.
I might get medium CA in the 3/8 but most anything would be scraped off the 1/2". 1/64 smaller bits seem too tight to drive in.
If anyone has used wood handles I would like to know how to get a tight fit in wood?
I sure like the feel of wood over metal handles.
Thanks
Re: Wood handles for Thompson lathe tools
Darryl
>Try Gorilla glue or any expanding polyurethane type waterproof glue.
Keith Tompkins
keith tompkins
>You might try putting the gouge in the freezer , then apply glue and install.
arkie
>One thing commonly overlooked is the need for a weep hole through the side of the handle into the bore just above the bottom. This prevents air-locking a very tight wet fit or hydraulic locking a slightly looser fit. 1/16" or even a bit smaller is sufficient. Think in terms of installing a chair rung in a leg and you'll be on the right track.
Steven Antonucci
Honestly have never measured?
steve antonucci
>If it's a 1/2" gouge, I drill a 1/2" hole. If I happen to have something 1/64" smaller I'd use it, but either way you'll be fine.
If it's 1/64" under, you won't even need glue. Use it anyway, but I wouldn't worry about it. I tend to set mine pretty deep, and I've never had one fail.
Steve
pretty deep
Thad
>Steve,
Can you give us a ballpark of "pretty deep?
Bill Howatt
>You likely don't need anything but I often use 5 minute epoxy just o make me feel better. Gap fills if you need it and a film will bond just fine where there is no gap. I also drill a vent hole to let out the air or excessive glue.
Bill
Steven Antonucci
As deep as I can
steve antonucci
>I usually drill as long as the bit I am using will allow me to. I love my Doug Thompson detail spindle gouge that I bought from Doug at Five Barns, but it's pretty long. I buried as much of the unfluted part of the gouge in the handle as I could.
There is almost no reason that an average gouge needs to have a huge length of steel, and certainly no reason to have 6" of flute, unless you have no idea how to sharpen at all. I try to balance the length of the handle with the overall length of the exposed steel, and most of my tools have at least 3" in the handle, some even more if I had a longer drill bit.
Hope that helps
Steve
Re: As deep as I can *LINK*
>Same here - the gouges have a very generous length but most are too long for practical use.
For wooden handles, I use machined aluminum handle inserts with two set screws to grip the shaft - very similar to the ends of the monster and other metal tool handles. While the handle blank is still on the lathe, I drill the large hole needed for the insert then drill a smaller hole 6" deep or so to allow the tool shaft to be buried as much as needed. For small tools I leave only a few inches out the end.
I bought a supply of these inserts from someone who had them machined. I see craft supplies carries them but the cost is pretty high. It would probably be cheaper to get a local machinist to make up some.
handle insert
>Epoxy will hold them in quite nicely. I drill a 1/16" hole through the side of the tool handle near the bottom of the hole. when you push the tool into the hole hydraulic pressure will try to push it back out. The hole in the bottom lets the air out relieves this pressure. A little epoxy usually comes out as well and conveniently fills the little hole. Simply wipe off the excess epoxy.
Fog Tanner
>I use a bit that is the same size as the machined portion of the tool. I use one or two brass inserts and 1/4-20 set screws. I use one on the 3/8" tools and two on the 1/2". If the hole is one or two thousandths over, it doesn't appear to be a problem. I have no problem with the set screws and the tools rotating.
I just like the set screws, as it makes the tools easier to sharpend and for trans porting. I use the same handel for my 1/2" U and V bowl gouges, another for my 1/2" spindle and detail gouges, and the same for my 3/8". Since Doug made the tang the same size on the 1/2" and 3/4" skews, I have just one handle for those two tools.
Fog the other handles and the tool was fixed, when the bar was smaller than the hole, I use 30 min epoxy to fill in. I would put some epoxy in the hole and around the opening, then push the tool in and wipe off the excess and let it set for a couple of days. I also do this with scrapers.
I recently saw Mark St. Ledger's handles, which are a neat idea for smaller tools. He uses lengths of 1" or 1 1/4" sch40 PVC. He turns a dowl with a 2"-3" tenon that fit into the PVC. He drills and taps through the PVC and into the wood for 1/4-20 set screws. Has 3/8" on one end and 1/2" on the other. Not sure I would do that with bowl gouges, but looks like it worth a try for spindle gouges.
Fog
Burn them in
nick
>I use the old-fashioned way: drill a hole the same size as the tang (shaft) and burn it in to the handle. This is one tight fit. If you ever want to put a new handle on, then just burn it out.
Like Steve says above, it seems like Doug's tools are too long. In the future, I think I will cut off some of the shaft and bury part of the flute in the handle. If the gouge ever gets too short in my lifetime, I can always burn it out to lengthen it.
2" is a good rule of thumb.
Brian Hahn in SW Wisconsin
>I make wood handles for all my tools (hate the factory handles).
I drill the hole slightly undersized if I can and then drive the handle onto the tool. Put the tool point down onto a scrap of wood, position the handle above it and hold it in position while you drive the handle onto the tool shank. A heavier hammer works better. I leave a nub on the end of the handle to take the abuse and then cut it off afterwards. Another method is to use the tail vise and bench dogs on a woodworking work bench. (It will creak and groan a lot.)
If the handle is just slightly loose, I'll add a little super glue around the top - it wicks down and seals the joint well. For loose fits, I use epoxy.
I've burned handles in. They hold very well (had to chisel the handle off the tool when I replaced the handle) but it set off my smoke detectors.
Steven Antonucci
Agree 100%
steve antonucci
>The thinner the tool, the less length I would expect, and the shorter the flute should be to retain mass and lower vibration.
The more that hangs out of the handle, the harder it becomes to dampen vibration and the more the overall tool length starts to get in the way of basic cuts.
A part of me(the practical) almost hacked two inched off of my detail gouge before the other part(the frugal) of me stopped it...
Steve
long
>I guess I'm different. I like my gouges and handles fairly long because I do all my turning with body and I like the handle on my hip. Regarding flute length. I also like a longer flute because I sharpen a lot. My tools do last a very long time because I remove very little metal and a longer flute simply means they last longer. Tools are expensive and I want the most for my money. I do think they are a wonderful bargain because properly ground they last a very long time.
I don't think it necessary to sink the steel in the handle all that far for strength. The weak point on a wooden handle is where the back of the ferrule meets the wood. This is where the thinnest wood is, and is also where I've seen them break. I like to have the metal about 1 1/2 to 2" beyond this point into the thicker part of the handle.
Doug Thompson near Cleveland
>I like to use medium CA because of the longer working time over thin CA, it really doesn't take much to lock the tool in place. Also I run the shanks slightly undersize (.003 is the thickness of a sheet of paper) so ther won't be a problem with the handle bore... .499 in a .500 bore is a tight fit.
To bury the tool farther in the handle bore the hole 1/64 oversize, that's the diameter of the steel before it's turned down to size. If the tool is still to long cut the flute down an inch or two... to long is better than to short.
Bill Grumbine - Kutztown PA
>Yeah, if the tool is too long, it will get shorter eventually! I like them long. In fact, I like them so long, I got Doug to make me a special bowl gouge that is about 16" long. And that's just the steel! Some of you have seen the completed tool. And, you have seen how it works.
And some of us got to try it !
Don Orr
>That is one wicked tool-long steel, long heavy handle and it can really move some wood !
Thanks all for your input
GalenV
>The weep hole suggested by some seems like a good idea for the fits my drill sizes will allow. The undersize bits looked like from a test piece the hard maple was not going to give much and would need to add a chamfer to the tool end and hope things did not split. Thicker CA will probably be used. The expanding glue has not been my friend as I have not used enough to realize a VERY little is enough or you really end up with a mess to clean up.
The Thompson 3/8 detail gouge is at least 1 1/2" longer than a cheaper one I have so will take some adjustment in use but I do not want to cut or grind off good steel.
Thanks again to all for your comments.
Galen
GalenV
>Thanks to you all for your input.
Finished Thompson bowl gouge and detail spindle gouge with hard maple handles and brass ferrules from left over tube fitting.
Just need to set up varigrind and record setup to match the grinds.
Steven Antonucci
CA glue in an Ash/Oak handle too!
steve antonucci
>Once found myself semi-glued to a new tool handle from the glue being pushed out the pores!
Steve
Re: Burn them in - Burn say who say what?
Ray Carson, Lawrenceville, NJ
>Burn the handle in? Can you all explain.
Thanks,
Ray
Re: Burn them in - Burn say who say what? *LINK*
>I assume the technique mentioned is one sometimes used to seat a square or rectangular metal tang into a wooden handle. Drill a hole so the tang doesn't quite fit, heat the tang, then push it into the hole. The wood is burned away on the corners and makes a tight fit. I've done this but I hate to heat the tool that much.
Doug Thompson has an article on his web site (written by Ron McKinley) which shows an alternate method using finesse rather than force (link). Good article, BTW, in general for making handles.
http://www.thompsonlathetools.com/handles.asp
nick
>Ya. Used to be the standard blacksmith method of handling a tool. Make the handle, drill a hole smaller than the tang of the tool, then heat the tang to 500-600 degrees and hammer the handle on. Smoke pours out of the handle but when the tang cools, that handle is locked on. If you ever want to remove the handle, just reverse the process. Quick, easy, foolproof and no glue needed. Glue is irreversible.
