Wood Bleach
Wood Bleach
Wood Bleach
Dinyar Chavda
>I can't seem to find the 2-part wood bleach in any of my local stores, and I'd like to avoid getting it by mail, as I am cheap, and hate to have to pay for transporting water.
So, that leads to 2 sets of questions.
  1. What's wrong with using plain old clorox? Would it work? Are there any precautions one should take?
  2. Assuming that one can't use clorox, is the hydrogen peroxide in the wood bleach the same concentration as what one gets in a drug store? Is there any kind of store where can one find the sodium hydroxide component?
TIA
D
Re: Wood Bleach
Re: Wood Bleach
Chuck Engstrom
>Two answers:
Clorox -- no harm in trying. I don't have any experience here to guide you. Oxalic acid is another possibility, used often to remove rust stains, but I don't know how it would do on wood. Check farm stores or plumbing supplies.
H2O2 -- probably not as strong as the stuff in the KleenStrip kit.
Did you try Home Depot & Lowes? I've seen it in both though by now the suits at HQ may have banned it for liability. My local Ace had it in their paint department. If you can find it, shelf life is essentially unlimited.
Chuck Engstrom
Re: Wood Bleach
Steven Antonucci
Chemistry answers...
steve antonucci
>I'm pretty sure you've already answered most of you own questions. As you indicated, wood bleach is not Clorox, but something entirely different.
In most of my research into buying chemicals from supply houses, I have found that it is nearly impossible to buy them locally in small quantities. Even with a brother that is a chemist, I have yet to identify a source for "a little bit of compound X". Think 55 gallon drums...
steve
Re: Wood Bleach
Re: Wood Bleach
>Hi Dinyar,
I use Clorox a lot when restoring old houses. I works quite well in many woods, not so well in oily ones, but it is not on the league of the 2 part bleach. Oxalic acid is great to remove rust stains, but otherwise is just too mild. Clorox if used on a sunny spot works quite well. Some people swear by 50-50 mix with water, i use it full strenght, leave it on the sun and if not enough, repeat the treatment, when satisfied, rinse with water and allow to dry.
I cannot get chemicals in small quantities, the last time I inquired I was forced to LOTS OF RED TAPE, just for asking, and I got nothing!
I cannot get the 2 part bleach around here either
Hope this helps
Jorge
Re: Wood Bleach
Re: Wood Bleach
>Did you try the paint stores. I can get it around here at Lowes, my local Ace Hardware and at Porter Paints. The stuff I use is called Kleen strip
Re: Wood Bleach
Re: Wood Bleach
Harry In beautiful downtown Kulpsville
>Dinyar, I got some at the Woodcraft store in Allentown. That is a pretty long haul for you unless there is a store nearer. Try calling some of the local paint stores. Some carry it.
Re: Wood Bleach
Re: Wood Bleach
Wally Dickerman in Arizona
>I got 2-part wood bleach at Woodcraft. Cost was $16.99 and they claim that there is enough to cover 15 to 20 square feet. That's a lot of woodturning pieces.
Wally
Re: Wood Bleach
Available in Small Town, VA
Barbara Gill, Remlik VA
>I picked up a box of KleenStrip Two Part Wood Bleach at our local lumber company in the paint dept.
Re: Wood Bleach
Re: Wood Bleach *LINK*
Russ Fairfield
>If you really want to bleach some wood, bite the bullet and buy the best. It's from Daly's Paints in Seattle, WA. It doesn't come any better than this. Of course, you will have to pay the postage. I think it is worth the extra cost.
Daly's Wood Bleach
Re: Wood Bleach
Re: Wood Bleach
Dinyar Chavda
>The local HD used to carry Kleen Strip (Strip Kleen?) in their paint department, but they informed me that they've stopped doing so. Lowe's had never heard of it. I'll try calling the local paint stores and Ace/Tru Value stores.
Steve/Jorge, I was hoping that the sodium hydroxide was a common product sold under some other name in a drug store.
Harry, you're right, the gas to get to Allentown would be more than the shipping. I can get it from them, Wally and Harry, but it would have to be by mail.
I don't know why I am so much more offended by the thought of paying to ship water than for shipping anything else. There is probably a psychology PhD thesis in that! Hmmm.
I might just get that Daly's product, if I have to get something shipped, Russ.
Re: Wood Bleach
Re: Wood Bleach
Dinyar Chavda
>Forgot to thank you all for your replies.
Re: Wood Bleach
Check your email
gil jones
>Dinyar, I have two files on bleaching wood, but they are too big to post here, so they are on the way to you via email. If anyone else wants them, just ask.
Gil
Re: Wood Bleach
Re: Wood Bleach - some technical info *LINK*
Brian Hahn in SW Wisconsin
>First, chlorine bleach (Chlorox) will work as Jorge Castaneda indicated.
The hydrogen peroxide from the drug store isn't as strong as the stuff in the two-part bleach package, but it will work. Albeit more slowly and it will require more applications of the hydrogen peroxide.
The lye solution in the kit is 5-10 gm per 100 ml. I've made my own solution, about 1 ounce of lye per pint of water (6 gm per 100 ml). Lye is (or used to be) sold as a drain cleaner. I got mine from the hardware store. I haven't bought any in a couple of years so I don't know if it still is available. I can't give you a brand name - Red Devil was a lye once upon a time, but they changed to a non-lye formula three years ago.
I posted some additional information a year ago - see the attached link.
Previous bleach message
Re: Wood Bleach
True-Value has it too
>Dinyar, you didn't mention the wood you're trying to bleach or what you're trying to accomplish with the bleach. If you want to bleach all the color out of the wood, I recommend you find the two-part bleach. I've tried the others and they don't do it. Oxalic acid, as someone mentioned, lightens wood just slightly and makes black iron rings on the wood disappear like magic. I've found that chlorine bleaches work on certain dyes but they don't lighten medium to dark colored woods very much. Maybe stronger concentrations and longer exposure times would work.
Re: Wood Bleach
Thanks, Gil & Brian.
Dinyar Chavda
>Thanks, Gil & Brian. I'm not sure I'm brave enough to use this technical information--when I was in college, every time there was an explosion in the chem lab, people looked at each other, and said "Chavda must be trying to do something!"
Re: Wood Bleach
Re: True-Value has it too
Dinyar Chavda
>Unfortunately, our local TruValue does not have it (nor does the Sherwin Williams). They only carry an Oxalic Acid product.
What I'm trying to do, Ellis, is to bleach out all the color out of parts of the wood to provide interest through contrast and design. I've done a couple of pieces, and am running low on the bleach, which is why I need to replenish it.
Below are rough pics of two examples. The one on the left is unfinished, and is a piece of poplar yin yang design within an off-center natural-edge platter. The piece on the right is a finished walnut, with designs on both bleached and unbleached sections.
D
Re: Wood Bleach
>Thanks for the pix, Dinyar. I had a feeling you were up to something unusual. Well, I'm sorry for the bad information. I thought Tru-Value stores all stocked pretty much the same stuff.
I've never gone the do-it-yerself Drano/H2O2 route, but it might be worth a try.
Re: Wood Bleach
Re: Wood Bleach
Joe Flemig
>Wally, That kit will do way more than 15 to 20 sqft. I would guess a couple of hundred x 1 coat. I typically bleach wood four or five times to get it as white as possible. Joe
Re: Wood Bleach
Re: Wood Bleach
Pascal Oudet
>Dinyar, 2 part bleach is not available on this side of the pond.
for years, I've successfully used the following method:
- 1 coat of lye (NaOH), let it dry a bit (don't be afraid, the color will darken as it will pull out the tannins). someone said it's sold as drain cleaner, it's also the case here. you can dilute it, I usually use 20%+80% water.
- 1 coat of hydrogen peroxyde (30% stuff)+5% of ammonia
This receipt comes from a book (probably around 100 years old) that lists many old recipes for furnitures, with products with funny names, or products that don't even exist anymore. it's still valid today, wood hasn't changed since.
Pascal
Re: Wood Bleach
Re: Wood Bleach
Peter Hyde
>Dinyar this is the bleach kit I use http://www.woodkote.com/ called Light'n'up
Their price for a 2 one pint kit is $12.99 plus shipping.
I can't get it shipped into Canada so i buy at a local commercial paint store and the price gets to be $50 including taxes. So don't worry about your shipping costs :-((
Re: Wood Bleach
Re: Wood Bleach
>Pascal,
Thanks for the info, your recipe is basically the same as the commercial 2 part bleach.
In this side of the pond, the 30% peroxide is not easily available unless in big quantities and lots of red tape.
Jorge
Re: Wood Bleach
Re: Wood Bleach
Dinyar Chavda
>I decided to bite the bullet and follow Russ' recommendation, and ordered the bleach from Daly's. The product cost under $16, but the shipping was over $10. It's a good thing I had planned ahead, and did not need to have it overnighted to me---shipping would have cost $77!!!!
Thanks to everyone for their advice and help.
