Long before we were here...
Chuck Engstrom
>... this piece of wood was growing. What's left is a 5-3/8 diameter ball, turned this afternoon. I do a fair number of these for a local shop, and every once in a while I get one with a notable number of growth rings -- this one had 296, by my count, and you can see that the rings are pretty straight, suggesting that this chunk did not come from anywhere near the center of the tree.
Other pieces I've seen have remarkably varied growth ring patterns -- a bunch of very tiny rings surrounded by groups of larger ones, indicating periods of very different growth conditions -- which makes me wonder what's going on in trees now growing during "global warming." There's some of this in the photo, but far less variation than sometimes appears.
Best to all--
Chuck Engstrom
Re: Long before we were here...
Don at Central Illinois
>Do you have a 'special' way to turn spheres, or do you just eyeball it? I am still having a heck of a time turning a perfect, or somewhat perfect sphere.
Steven Antonucci
That is a sexy piece of wood!
steve antonucci
>I'm in love with that tight ring count! 50+ rings per inch.
What is it? Some old growth pine? I've always wanted to get my hands on something special like that. I see those trees hiking in Yosemite and I wonder how much they've seen that I could only imagine...
Steve
Texian
>Don,
There's a tutorial on that, but can't find it at the moment. Basically you turn a cylinder between centers, diameter "D" and length "D", with an inch or so extra on the ends where the centers are. Then mark xD distance from the "corners" in both directions (axial and radial) and turn that at 45 degrees. Then mark yD in both directions from the resulting "corners" and turn between those lines at 22-1/2 degrees. One more step and you almost have a sphere. x and y and my good calculater are out in the shop, but hope you get the idea, and someone here will know where the tutorial is to be found. It works.
Chuck Engstrom
>To respond to the several queries here:
These balls are roughed out on a large Hapfo duplicator lathe and I just tidy them up and finish them to a decent surface, etc. I usually sand just to 120 but to count the rings on this one I had to go to 400. Museum-grade perfection is not a goal, as they are intended for tops of sign posts, etc, commonly seen at a distance from a moving vehicle.
It's red cedar.
I have a spreadsheet for the method Texian mentioned, but don't use it here as these are already shaped when they come to me. I'll be glad to send it along to anyone who wants it. Just type in the diameter and it gives you all the proper figures. This is, I think, the method Myron Curtis wrote up a few years back in AAW magazine.
Best to all--
Chuck
Steven Antonucci
I'd save this one...
steve antonucci
>much too much history to be put on top of a fence post...just make another one out of "ordinary wood".
It's art as is.
S
x=.56
Robin Corell in Atascadero CA
>x=.56
I'm not familiar with the rest of the method, but I would very much like to know the constant for 'y' as I use this method for making large round overs with a spokeshave in my flat work.
Robin
