So I happened upon some walnut today and proceeded to start cutting. I found that the bar/chain was getting clogged up pretty quick with the green wood. Is this normal for walnut (I've never cut it before) or should I be looking at something else? The clogging was sufficient to stop the chain, even under full throttle. Lots of bar oil in the tank and on the chain. The saw is a Stihl MS390 and has all original parts. I bought it in January or February.
Things I have thought may be the culprit... Too much tension on the chain, too much/little bar oil, the wood.
Your help is appreciated.
Steve Kubien
P.S. Did manage to get 4 large bowl blanks and a few small pieces prior to being fed up.
Are you ripping or cross cutting. If your ripping and getting those long fibers that gather under the gear cover try varying your angle of cut which might get you smaller fibers that don't mess up and stall the saw. If your getting the saw stopped when cross cutting it must be strange wood?
>If you are cutting REAL green an wet wood,you have to keep the saw a ways back to let the shavings come out the bottom.It can be a pain,but somtimes you just gotta get a stick an clean it out when it plugs up.As for walnut itself,I cut it more than any other wood up here and never have that problem with it plugging up the saw and I use everything from a small poulan to a Homlite C72 (A monster)So it doesn't seem like it should plug that bad boy up that you are using.
>Thanks Ken. I didn't really think it was the wood but I had to ask (no such thing as a dumb question eh?). It sounds like between the tension and the angle of attack, I have some things to look toward.
>Do you mean A) the chain teeth were clogging, possibly including the housing around the socket jammed full of chips stopping the chain there, or B) the space under the chain and above the groove in the bar, especially at the tip, or even the groove itself, was clogged with finer fibers such that the chain would not move freely on the bar?
I've had that problem when the chain was too loose, if the groove in the bar and/or the chain was worn causing too much clearance, if the log was large which required plunging the tip into the wood, if the wood was very wet and gummy, and especially if the chain was dull (the dull chain would make more dust and small torn fibers than a sharp chain and these can compact under the chain at the tip) and perhaps when I was pushing the chain a little too hard into the wood, possibly because of the dull chain! (A pinched chain can do this too.) I've had to remove the chain and carefully clean the bar groove with the proper tool, clean the tip sprocket and lube until it would spin freely, and perhaps flip the bar as a temporary measure.
If the groove in the bar is worn, you can repair it with a little roller tool. Before I got the tool I would tighten grooves with a hammer but that can be tricky. Note that it is important to turn the bar over every couple of times you sharpen the chain to even out the wear on the top and bottom. I also file the bar occasionally to smooth the contact area. If the chain is worn excessively, it can cause early wear on the bar. I probably replace the bar every few years. (I keep an extra new bar on hand.)
If the chain is too loose, it will allow more gunk to get underneath. As the chain runs it gets hot and expands, so it may start out tight then get loose, especially (again) if the chain is dull or worn which will increase friction and heat. It's best to run the saw a bit then stop and retighten the chain. I like the chain tight enough to spring a bit when I pull it away from the middle of the bar.
Also check for wear on your sprocket. I've had to replace it in the saw I use the most. A worn sprocket can cause all kinds of grief and can prematurely wear out a new chain.
I think your immediate problem has been covered by others.
One thing you should look at, if you are ripping a lot, is to adjust the oil flow up. There is a screw on the bottom of your saw that lets you increase. it needs extra oil for ripping.
>My MS390 does it at times, also. I stop, re-adjust the chain, and clean the groove in the bar. Then I change the angle of attack, and that usually works. :o) I think it's caused when I am trying to rip at too flat an angle.
The book tells you that the chain should be tight enough to spring back to the groove when you lift it out, but still be loose enough to have just a tiny sag when you look at the chain at the bottom of the bar. So it's a little hairy trying to get it right. Mine loosens as I cut quite a bit of wood, and I don't keep it tight all the time.
Also, I noticed this problem when I was ripping wet sweet gum and wet fir.
>If this has been mentioned (sorry)but if you are doing a lot of ripping,then you should have a chipper chain,they have much larger teeth and are more suited for that.The reg cross cutting chains don't do well for ripping.Or in other words,get the biggest tooth chain your saw can handle.
>You can turn a normal chain into a ripping chain by regrinding the teeth. One set of instructions involved grinding away the tops of two out of every three teeth, leaving the edges to stand up on either side of the kerf, then sharpening the remaining teeth straight across but with a "blunter" angle. The teeth with just the sides shear the fibers at the edges of the kerf and the others chip away and remove the wood.
Another reference recommends sharpening the teeth at 10 deg rather than straight across.
From reading threads on the sawing forums, these modified chains can work very well if sharpened correctly and poorly otherwise, however, most people who mill with a chainsaw prefer to buy special ripping chains, with chains from Oregon the most often mentioned. (link)
(I did a lot of research into this when trying to decide what direction to take towards milling logs - I ended up deciding on a Woodmizer bandsaw mill.)
>Try talking to the folks at bailey's. You can buy a dedicated ripping chain. Web site is baileys-online.com. I now buy all my chainsaw supplies there. Nice and knowledgeable.
>I hadn't thought of a ripping chain. John, I have real aversion to altering things like tooth geometry. Too scared I'll screw something up and get hurt. And, what is this, "10 degrees" thing you speak of. Oh, that's a measurement?!?! Its been so long since I touched flat work tools (including the ones with numbers on them) that I am not sure I remember how to measure things like an angle. Part of the reason I like turning is that I don't have to do those sort of dark, evil things.:)
I have a confession to make, from the deep, dark cracks of my soul. After preaching the simplicity and ease sharpening a chain saw by hand with a file, I broke down and bought a sharpening machine this summer. (Don't let this get out!)
While I still use the file for most sharpening (the chain should be touched up with a couple of file strokes every other tank of fuel or so), the sharpener is wonderful for putting a badly damaged chain back in good condition with almost no effort, perfect angles and all. I had a chain that had been run into metal in a log then into rocks in a root ball and I was able to grind it back into shape very quickly.
I still don't advocate taking the chain to the neighborhood chainsaw shop since they typically set it to the worst case tooth and waste a huge portion of the life of the chain, but when doing it yourself it's easy to grind away only what is needed on each tooth. (Contrary to what's commonly advised, it is not necessary for each tooth to be the same length.) The shop certainly doesn't care if your chain is worn out quicker - in fact, that means they might sell you another one sooner.
These little machines can be fairly inexpensive unless you get a fancy one. And nothing to measure! You can concentrate on sharp rather than angle.
