Dry Lignum Vitae?
Dry Lignum Vitae?
Dry Lignum Vitae?
Ruth Niles
>I've got a few 3" sq. lengths of Lignum Vitae and the wood chips when I turn it. There's plenty of natural oil/wax because my tools get coated while turning.
Is it just the wood I bought?
Is it dry?
Is there a solution?
Yes, my tools are scary sharp.
Yes, I'm taking light cuts.
Thanks,
Ruth
Re: Dry Lignum Vitae?
>Ruth I was given a chunk this weekend but haven't turned any of it yet. It's really odd shaped with some little checks so I'm not sure what I will do with it. I look forward to seeing what other people have to say on the matter.
Gary Evans -- Tallassee TN
>Hi Ruth,
You can dry a piece in the oven to find out exactly what your moisture content is, but lignum vitae has a reputation as an oily wood. It was used for years as a bearing surface for spinning shafts such as propellors, axles, etc.
Gary
Barry Elder
>You could use a bigger wrench!! Sorry, Ruth! I just couldn't resist! Have a GREAT DAY!
Wally Dickerman in Arizona
>I once bought a small LV log that had a date stamped on it that went back 50 years. Surprisingly, there was still some moisture in the heartwood. LV is a very waxy wood. When turning it I had to stop frequently to scrape the hard wax off my tool. At the time I was turning letter openers and I turned some from LV. I was surprised when some of them warped. I sold them as left-handed letter openers.
Verawood has the same waxy substance.
Wally
Thank you, but.
Ruth Niles
>What causes it to chip? It's got plenty of waxy substance, I have to stop to clean it off, too.
Perhaps it just from a part of the tree that had stress wood? It's very annoying and I have 4 more pieces and jobs to do and I'm not having fun!
Barry's right, I need a bigger wrench......... : )
try a scraper
Robin Corell in Atascadero CA
>Try using a scraper rather than a cutting tool. LV doesn�t require particularly sharp tools and will produce a nearly polished surface if you use a sharp scraper.
Robin
Re: Thank you, but.
>Ruth, I can't recall that I had any chipping problem as you are having. I agree with Robin, using a scraper on very hard dense woods such as LV, works well. Might be worth a try. A neg. rake scraper will leave you with a mirror finish.
Wally
Rick Allen
>My limited experience with LV is that it turns beautifully but slowly. The depth of cut was slight and the shavings coming off were wonderful little waxy curls.
I found that the wood chipped if I was to aggressive or if I was turning against the grain. Tool presentation, angle of attack and direction of cutting were all very important with the LV I turned. Because of this I avoided turning much in the way of details. Coves worked better than beads for me. And the coves were shallow and long.
The end product is nice for a few reasons.
The wood color is unusual
The weight is surprising to most folks
The texture off the tool is nice
Good luck with your LV
Mike Rubes, Apex, NC
>Hi Ruth,
Just adding my 2 cents to the discussion. I've turned a bit of lignum and really like it and have sometimes seen the chip out you are talking about. With me, however, it usually means I am spinning the piece too slowly and my tools need a sharpening. I've found that light cuts are the way to go as the wood is very, very hard and often seems a little "brittle" when cutting.
End grain tearout is minimal and as Wally pointed out, if you scrape carefully, you can get a really great finish straight from the tool. To, me the wood is worth the effort because you can put some good detail in it.
Good luck!
Mike
Time to clean the shop in Apex, NC
>I get chips and side grain tearout on osage orage spindles when planing with a sharp skew. I saw a tip recently where Mike Darlow said a technique for preventing tearout in problem cases is to run the tool backwards when cutting, whether planing with the skew or the gouge, i.e., pull the tool bevel first rather than edge first. If I remember, he said this won't take off much wood but it will reduce chips. This seemed crazy so I tried this on a piece of cherry just to see how the tool handled. It certainly cut wood, but I did not yet try it on a "chippy" piece.
Carole Valentine
>LOL! Ruth doesn't do anything slowly - could be that's the problem. ;))
Ruth, it's just the nature of ...
Allen Neighbors
>Lignum Vitae. Until the late 70's or early 80's, Lignum Vitae was used for bearings for the propeller shaft in large ships... even in our US Navy!
It has a natural lubricant in the wood. I have a piece that will become two bearings in a jack-shaft to lower the speed of my Little Vic (if I can ever find that round tuit.) :o)
Re: try a scraper.....and thanks
Ruth Niles
>Thanks, Robin and since Wally agrees with you, I guess it's the way to go. I'm turning bottle stoppers that I call the "Vineyard Monk" so there isn't a lot of room for a scraper. I took this picture quickly so excuse the shadow and clarity.
I'm getting the tear out, or chipping, coming from the bottom toward the neck.
I think there were some good suggestions, using a scraper, trying to go with the grain (not always possible) and going slower (I'll have to concentrate on that one).
Thanks for all the help.
Texian
>Very cool stopper design!
aggressive turner ? :)
Dave Peebles Lyons, Ohio!
>Sorry Ruth,
I just had to do it. Man, does that make me feel old.
Best wishes,
Dave
Re: aggressive turner ? :)
Ruth Niles
>Dave, that's one I will never live down! And I must confess, I am aggressive at times.
Don't feel "old", you're "experienced". : )
