>I seem to have grown fond of the friction polish finish. However, as most of us are prone to do, I am always looking for a less expensive outlet. Does anyone have a recipe for a home brew for a friction polish?
The use of shellac as a protective coating appears as early as 1590 in a work by an English writer who was sent to India to observe the country and its people. Commenting on a procedure for applying lac to wood still on the lathe he writes "they take a piece of the lac of what colour they will, and as they turn it when commeth to his fashion they spread the lac upon the whole piece of wood which presently, with the head of the turning (melteth the waxe) so that it enter into the crests and cleaveth unto it, about the thickness of a mans nail : then they burnish it (over) with a broad straw or dry rushes so (cunningly) that all the wood is covered with all, and it shineth like glass, most pleasant to behold, and continueth as long as the wood being well looked unto : In this short they covered all kinds of household stuffe in India". *From Shellac; its production manufacture, chemistry analyses, commerce and uses." London, Sir I Pitman & sons, Ltd.,
I consider myself frugal but it is not worth it to me to experiment with a recipe for a friction polish. I don't keep all of this stuff on hand so it would not be cheaper for me. I have been using a container of HUT Crystal coat that I got with my used lathe more than a year ago. It was partially used and I have used it for all of my small spindle turning projects (including more than a hundred Christmas tree ornaments) and I still have a lot left. When it goes I will probably try a different brand.
>Be careful with very old containers of friction polish. Since it has a shellac component, it also has a shelf life. I used an elderly bottle of Hut Crystal Coat about a year ago and found it did not dry properly. Called their '800' number and was told about the shelf life.
BTW, friction polish works well on small object that are not handled often. But on a pen, that may be used several times each day, the gloss soon disappears leaving a 'muddy' looking surface.
>I have been using Mylands sanding sealer and then Mylands Friction Polish and really like it. I think I have tried everyone that it on the market and Mylands works best for me. When I do a bowl I just use the sealer and then the beall system. Turns out great.SAM
>I use approximately equal parts denatured alcohol, shellac and linseed oil. Shake well before using. I prefer to use pale shellac made from flakes. For light colored wood substitute tung oil for linseed oil. A small amount goes a long way so mix ounces not cups.
Tip - Make sure the lid is screwed on before shaking. DAMHIKT
Dave Smith
Spilled my friction polish than I have used in Longview, WA.
