crushgrind pepper mill help pls
C.B.
>I want to turn a pepper mill and install the Crushgrind works. I have the instructions from Crushgrind and they indicate that a groove should be turned into the base and the head to accomadate the mounting tabs of the mill. This would then make the mill works just snap into place.
My question, is this the best way to do this or does some one have an alternative method. I think I could modify an allen wrench to use to cut this groove.
Anyone with experience with the Crushgrind pepper mill please give me some advice! Thanks in advance.
Re: crushgrind pepper mill help pls
>C.B.,
I made some with these mechanisms. (I like them)
I've read advice on someone's web site to just cut off the tabs and glue the mechanism into the mill but I didn't do that.
I marked the exact location of the groove by inserting and rotating the mechanism after applying a little pencil graphite on the tabs. I used a hand-held Dremel tool with a little toothed disk cutter to cut the grooves, just where needed for the tabs.
It would be fairly easy to grind a small "L" on the end of a tool to cut the groove on the lathe, but I didn't do that.
BTW, the set I made are from Cocobolo and Dogwood - I like the weights.
C.B.
>Thanks for the reply and advice. I may try the dremal tool, I had not thought about that. The two you did sure look nice. Great job.
>Thanks. Now I'll always be able to tell which one is the salt. :)
david
>I tried this once using the directions and purchased the various drill bits for the required diameters. The runout experienced while drilling the holes resulted in the parts not fitting very well. Saw others who glued in the different parts and told myself that I would do the same on future attempts with this mechanism. Waiting for inspiration to strike for a form/shape that I can live with.
I drilled with a carbide tipped forstner bit (with an extension) held in a jacobs chuck in the tailstock of the lathe. To keep the chips clear and the heat down, I blow compressed air into the hole behind the bit as I drill. I got no runout with this method.
Peter Charles Fagg (UK)
>I am glad to see that others are experiencing problems with Crushgrind mechanisms.
Not that I wish to inflict trouble on others, merely that I have just ordered some of these to try something different.
Knowing the possible difficulties beforehand should make the fitment easier!
Regards, Peter.
