tagua
tagua
tagua
dwfII
>Has anyone worked with tagua nuts? What I want to know is how durable is it? Could it stand repeated but not overly prolonged exposure (four to six hours at a time) to skin? And the moisture that might be on the skin?
Does it need a varnish or lacquer...especially when worn against the skin?
If bought from a reputable dealer, will the material shrink and crack if carved into its final shape immediately?
I am wanting to use tagua as the pommel of a knife that is worn against the leg.
Re: tagua
Steven Antonucci
Tagua is not a solid nut
steve antonucci
>The inside often has a pretty severe void in it. You'd have to be real careful. It's also pretty brittle, and tends to shatter and chip pretty easy.
As far as wear goes, I don't know, but it's pretty hard stuff. I'd be surprise if you wore it out.
Steve
Re: tagua
Re: tagua
E.T.
>Tagua nuts were used to make buttons before white plastic was invented, er... discovered. ET
Re: tagua
Re: Tagua is not a solid nut
dwfII
>I knew they had voids...all I need is a piece about 1/2"x1"x1".
I had read somewhere that they can be softened by soaking in water...in fact sometimes that is used to make carving easier. But how much soaking? that's why I asked about moisture and durability.
I might go with warthog tusk but there seems to be no guarantee that such tusks won't have cracks and so forth.
Re: tagua
Re: tagua
>On the larger nuts the void tends to be more in the center so you can often get a chunk 1/4" or more sliced off the side. If your lucky you might get 1/2". Of course you will still have what I call the "bark" on the outside. If you need a 1"x1" x 1/2" that is white all over, good luck. You might get lucky and get one side solid. You could fill the other side with clear epoxy or casting resin if that side won't be seen.
You can buy slices that big that are very thin, 1/8" or less from a company called www.turtlefeathers.com You could glue these up to make the thickness but of course you will see the joint on the side.
I would buy some white Inlace from the company above and simply cast a piece as large as you need. I would cast it larger and then cut it down to size. White Inlace looks more like acrylic when it's dry, which is actually what it is. Great stuff.
Re: tagua
Rob Wallace
Re: tagua
Rob Wallace
>It was asked:
*Has anyone worked with tagua nuts?*
Yes, I'm sure many on this messageboard have worked with tagua. I've turned a few tiny bowls and one hollow form out of tagua. Steve is correct - there is a void on the inside of the seed, so you'll have to be aware of this when selecting which part of the seed to use.
TECHNICALLY, what you get when you buy a tagua "nut" is actually the tagua SEED. The fruit wall (the nut proper) is hard and woody when mature and dried. The seeds are removed from this structure and sold individually; thus, the actual "nut" is discarded. The storage tissue in the seed (the endosperm) is what makes up the 'vegetable ivory' and is what is used to carve or turn small items with this plant product, which is harvested from a species of palm (the ivory palm, genus Phytelephas). The brown 'skin' on the seed you buy is actually the seed coat and not fruit (nut) wall..
*What I want to know is how durable is it?*
Quite durable. The so-called "vegetable Ivory" has been used to make buttons and other clothing ornaments for years. These clothes of course are meant to be washed, so the tagua buttons stand up to water pretty well.
*Could it stand repeated but not overly prolonged exposure (four to six hours at a time) to skin? And the moisture that might be on the skin?*
I suspect that contact with human skin would not be damaging, but the skin oils might easily deposit on (and stick to) the surface of the carved "nut". This is no different from other materials like wood or true ivory.
*Does it need a varnish or lacquer...especially when worn against the skin?*
Not really - most tagua turnings I've seen have been waxed and buffed - carnauba would be a compatible wax - it's also from a palm species.
*If bought from a reputable dealer, will the material shrink and crack if carved into its final shape immediately?*
The cells in tagua are pretty full of storage materials, waxes, and oils, and as sold by most dealers, the mature seed is fairly dry and will not shrink (as does wet wood) or crack, so final carving should remain fairly true without distortion. I've seen a tagua 'scrimshaw' piece over 60 years old, and there seemed to be no distortion in the intricate carvings on the surface. There are thousands and thousands of carved tagua souvenirs sold to tourists in many South and Central American countries and these apparently don't readily break apart. In my office I have carvings of a mccaw (bird), turtle, and lizard all made from tagua "nuts" that colleagues have brought me. All are fine; the oldest I've had about 16 years.
*I am wanting to use tagua as the pommel of a knife that is worn against the leg.*
As long as you select a good adhesive (e.g. epoxy) to marry the metal with the seed material, I think tagua might work in this application.
Try a Google search on 'tagua', and you'll see references for a range of applications for this plant product, and various explanations of places and items where the material is used. I get a term paper written on this species every few years as part of my economic botany course. It is quite interesting, and is a 'green', renewable product from the New World tropics.
Hope this helps - Good luck with your project!
(Prof.) Rob Wallace, Botanist (and Woodturner!)
Iowa State University
Re: tagua
Re: tagua
dwfII
>Thanks to all. The detailed response posted by Rob Wallace was especially helpful.
Re: tagua
Peter Hyde
>I found Tagua a bit of a pain to turn an went with this instead
http://www.woodturnerscatalog.com/store/Turning_Materials___Pen_Blanks___Alternative_Ivory_Blank___alt_ivory?Args=
Re: tagua
Re: tagua
Harry In beautiful downtown Kulpsville
>Check out this website:
http://home.att.net/~rspragg/index.html
This gentleman turns lace bobbins and seems to have done a fair amount of research on Tagua nuts. Worth looking at.
Re: tagua
alternative ivory
>Hey, I ordered two blanks just the other day to experiment with (a bit bigger than for pens). How does it turn? Does it look much like ivory?
Re: tagua
Re: alternative ivory
Peter Hyde
>It turns very nicely and yes it does look like ivory. I have to point out it is plastic and expensive plastic but it met my needs at the time.
