>Planning on a club purchase of a barrel quantity. Will have to ship to Honolulu, of course. We support our local Woodcraft, but at a recent price check, Anchorseal was $24 for a gallon. A bulk purchase could add to our club treasury and still be a savings to our membership. UC Coatings has not been very responsive to my inquiry. Can anyone help with a supply source?
I'm currently in the process of coordinating a group purchase of Anchorseal for our club - you should contact UC Coatings directly at the web site (or phone numbers found therein) below. They will give you a per barrel (55 gallons) quote, and you can discuss shipping options/costs too. They have excellent Customer Service!
Most of your cost to Hawaii will be freight, but I'm sure you're likely used to that...
I bought a 55 gal drum from UC Coatings a couple of years ago. It turned out to be about $6 per gallon or so. I mostly bought it for use with my sawmill, but I sold gallons to woodturning club members.
As Rob mentioned, UC Coatings provides excellent service. They also sell it by the 5 gal bucket.
You can buy it with or without antifreeze. I suspect you won't need the antifreeze!
If you buy a drum, you'll have to have some kind of nozzle/spigot for the drum. UC sells a quality valve to fit in the 2" bung but it is a monster intended for rapid flow. I bought a plastic adapter and spigot from a local supply house and made a cradle to hold the horizontally but raised off the ground enough to get a 1 gallon jug underneath. Perhaps UC has a smaller spigot.
>I have also found Anchorseal to be very responsive -- strange. You might want to talk to Kelly Dunn, another wood turner from Hawaii. There is a discussion going on about bulk purchases of Anchorseal over at WoW. One problem tackled is how to get the stuff out of a 55 gallon drum. Here are two of the comments -- I hope the authors do not mind me clipping and pasting this.
Kelly Dunn - Aug 13, 2008 Viewers | Reply to this item
Hugh, its very simple. 3/4 inch pvc or metal going into a 3/4 inch ball valve. i bought a metal one. More pvc or metal and one ninety degree angle. The valve needs put in while the drum is up. Then put over. Its heavy, more than 600 pounds. Lightly loosen a closing hole above your valve. This gets a little tricky till the level drops below the upper opening. I use a funnel to go into each jug. and its interesting to get that last gallon out.
Joe Johnson - Aug 13, 2008 Viewers | Reply to this item
Mark-- Jack has the right idea. A drum cradle and faucet is the solution. In my former life, we had them all over the place. The only thing I would suggest differently is find a brass faucet and fittings. If you broke a PVC valve while the barrel was in the cradle, you could have all of your Anchorseal on the floor.
>and thanks Bill, for calling attention to the discussion on WOW. I had no response from an email, but will contact UC Coatings by phone tomorrow. Will check will Kelly Dunn also.
