Wood Carvers Mallet
Wood Carvers Mallet
Wood Carvers Mallet
BobM
>A friend of mine wants to turn a wood Carvers Mallet. Does anyone know where to find plans or what are good measurements for making one?
Re: Wood Carvers Mallet
David Walser
>Not exactly what you are looking for, but in the video "Woodturning Projects Volume II with Rex Burningham and Kip Christensen", Kip Christensen turns a wood carvers mallet. The video illustrates the making of several projects and is worth the $20 it costs.
Robin Corell in Atascadero CA
>Measurements really depend on the type of wood and the intended functin of the mallet. Some carvers use a heavy mallet for roughing and a lighter mallet for regular work. I prefer chinese elm for mallets as it is reasonable dense and extreamly hard. the head is 3 7/16"diameter at the end, 3 1/8" diameter where it meets the handle, and is 4 1/8" long on the face. it sounds monsterously huge and for many carvers would not be suitable. I tend to choke up on the handle and in this grip it has a wonderful ballance and requires a minimum effort to work the chisel. this is the only mallet I have and for me it is perfect.
I have a friend who does a fair bit of carving and he detests my mallet and prefers one with a bronze head. I can't stand bronze headed mallets for the sound as well as the feel. its a pretty personal thing so don't be offended if what you make is not the perfect mallet.
Robin
Re: Wood Carvers Mallet *LINK*
Tom Stevenson
>Saw this over on the OldTools Archive....
Interesting use of exercise weights...
Just turn a handle with a thread and screw them on...
Presto, we have a mallet with interchangable heads...
Mallet from unused exercise weights
Does he have one already?
Jay in Tx
>Bob,
Does your friend have one already? Does he like it? If so, grab some measurements off of that one and scale up or down as needed for size, weight, aesthetics, etc. My current beating stick is in its 3rd iteration. It started out at near 'Commander' size (as in riving planks from larger billets/logs). Then it lost some weight and size when I needed a mallet for large structural joinery (note: usually 'Commanders' get so beat up hitting the froe, they just get burnt or discarded) After that, I just wanted a small mallet to set drive spurs and whack the odd peg, carving tool, etc.; so it is now slightly smaller than the ones you'll see in mail-order mags and at woodworking retailers. I think it is made of white oak.
I say all that to say this... make one and have him use it. You'll know soon enough what works and what doesn't to include durability, size, weight, length, angle of the strike face relative to the tool, aesthetics, etc.
Good of you to make something for friends, have fun!
~Jay
>If you live near a Woodcraft store, you could measure one.
I made a one a few years ago - I just made it "look right" and it's been fine. Use a tough, dense wood. Black locust or dogwood is nice.
Steven Antonucci
They're so quick and easy to make...
steve antonucci
>why not turn a couple? The only requirement is that you pick a nice, hard, heavy wood and you are set. I've used maple, ash and oak, and I don't go nuts "finishing" them, since they get such a rough life anyway.
When they are too beat up, I remount them and turn away all of the mashed up parts and I'm right back in business.
Steve
BobM
>Thanks to everybody for the good ideas.
Simple Mallet
Al Kapocius
>Saw a light mallet made from a section of brass pipe fitted to a handle. If'n you want more weight, put in a little lead.
Al Kapocius
Keith Tompkins
Re: Simple Mallet
keith tompkins
>A friend gave me a piece of brass 1" diameter x 2" long. The plan is to drill a hole in the mallet, insert the brass, part offf and finish. I liked his so much, I'm making one for myself.
