Hand Drums
Hand Drums
Hand Drums
chris krohn
>I am fairly new to woodturning and was just curious if anyone has any experience with making hand drums. I have seen some made from staves, and others made from a whole log. How thin is ideal, what wood sounds the best. Just throwing it out there
Peace
Chris
Re: Hand Drums
Re: Hand Drums
>I have seen a few articles over the years but couldn't bring anything up on google. Perhaps I spelled it wrong. I searched for Jimba drums.
Re: Hand Drums
Steven Antonucci
I think it's djembe
steve antonucci
Re: Hand Drums
Re: Hand Drums
>There was some earlier discussion on this forum
http://www.woodcentral.com/cgi-bin/turning3.pl?frames;read=179210
http://www.woodcentral.com/cgi-bin/turning3.pl?frames;read=182005
http://www.woodcentral.com/cgi-bin/archives_turning.pl?read=150628&v1
Re: Hand Drums
Re: Hand Drums *LINK*
Robin Corell in Atascadero CA
>I have a friend that makes drums for a living. He designed and patented a machine that cuts the drums from a log in such a way that he can get a whole set from one log. while technically it is a lathe it is very slow speed compared to what most are used to. He cuts the rough green blanks at about 1" in thickness and then cuts them to finished thickness after they dry.
Robin
Heartwood drums
Re: Hand Drums
Steven Antonucci
That is so cool!
steve antonucci
>I looked at his site, and I'd love to see the machine that cuts the cores. I understand if he wouldn't want to post it, but it must be a very cool thing to watch.
Steven
Re: Hand Drums
Thanks steve-my brain wasn't awake *LINK*
>I did a quick search on google for Making Djembe drums and came up with quite a few references.
http://www.drums.org/djembefaq/vVIII.htm
Re: Hand Drums
chris krohn
>I was on You tube and saw an interesting video about a guy who used his truck jacked up in the back, using his rear wheels as a lathe. Pretty backwood stuff :)
http://www.youtube.com/watch?v=wI-Ss6I5W7E
Re: Hand Drums
Re: Hand Drums
chris krohn
>I wonder what kind of shrinkage and or distortion the logs gets when the center is taken out.
Also bongo drums whould be ideal for me because they are significantly smaller and the way tying off the skin on the djembe seems kind of tough.
Cool Link, good idea of what kind of wood to use
Chris
Re: Hand Drums
Re: Hand Drums
r thomas
>Chris,
I have turned some Djembe hand drums . The latest one was turned for the Turned For Use II for the AAW sup in Richmond and I guess it looked ok as it was juried in . As I understand it thickness is not as important as weight, height, and diameter. I made the one for richmond out of Chinaberry and dyed it red .If I knew how to post a photo i would.
Re: Hand Drums
check the patent *LINK*
>>... I'd love to see the machine that cuts the cores
A full copy of the patent should explain the operation with enough detail to build one. Of course, you couldn't build one and sell it but you could build one and use it. Abstract below. The full text with diagrams is available from several sources including the one in the link below.
Inventor: Richard D. Ferdolage
USPTO Applicaton #: 20050166376 - Class: 02902700A (USPTO)
United States Patent 7069632 Issued on July 4, 2006
Agent: Law Office Of Philip A Steiner - San Luis Obispo, CA, US
Title: Coaxial and concentric cutting machine and a method for use thereof
Abstract: A concentric coaxial cutting machine which cuts cylinders, cylindroids or cones using a chain saw from a single larger object such as a wood tree trunk, a block of ice or a block of plastic. An embodiment of the invention comprises a transverse support member having directly or indirectly mounted thereon; a headstock member including; a headstock spindle member mounted to said headstock member including; a drive spindle rotationally mounted to said headstock spindle member and adapted to rotationally retain one end of an object to be centrically cut; a tailstock member including; a tailstock spindle member mounted to said tailstock member including; a tailstock spindle rotationally mounted to said tailstock spindle member and adapted to retain an opposite end of said object; a drive assembly in rotational communication with said drive spindle and adapted to rotate said drive spindle around a common axis with said tailstock spindle; and, a first chain saw variably aligned at an angle to said common axis and adapted to concentrically cut said object from at least said opposite end. (end of abstract)
Full patent text
Re: Hand Drums
Steven Antonucci
The lawyer is obviously not a woodworker
steve antonucci
>Unless the description is meant to be confusing and overt, it would have been cool to write it in English...
I'm sure the picture says it all, but it's not free...
Steven
Re: Hand Drums
Re: The lawyer is obviously not a woodworker
>Based on other patent abstracts I've read, including some of my own, I've come to suspect that obfuscation must be a legal requirement.
I thought the PDF of the full patent was available for free. A click on the image gives "You must be a registered user in order to access PDF versions of the patents. Not registered yet? It's free and easy." After you register, do you still have to pay? If so, there are other avenues.
Re: Hand Drums
Re: Hand Drums
chris krohn
>Was putting the skin on as tough as turning it, it looks pretty difficult. I came across some chinaberry a while ago, and is starting to check, bummer
Did you have to use a bowl/vase support because its fairly long?
Chris
Re: Hand Drums
Mike Jones, Redding, CA
>Chris,
One of John Jordan's links above show a djembe that I had turned. I studied this link: http://www.wwdrums.com/djembe-drum-head-replacement-instructions-a-15.html to learn how to skin it, and bought the goat skin from that site as well.
I didn't have a clue about any thing to do with drums, and (sadly) it seems that I really don't have the rythm neccesary to play it well. I made the drum body in two pieces, so the turning part was very easy.
The lacing over the ring is just a series of clove hitches, and you can see the details on the linked instructions above.
I used redwood that was a salvage timber from a very old-growth tree.
I found a drum teacher, and asked him to play it for me, and he said it had exceptionally good tone.
Here's a tip: Have your two rings in hand before you start. It will be much easier to size your drum.
Good luck, it was a fun and challenging project for me.
Re: Hand Drums
Steven Antonucci
Might be free, didn't try to register
steve antonucci
>I didn't take the time to go one step beyond...I get enough SPAM :-)
Steve
Re: Hand Drums
>What I do is keep an email account just for things like that. I never even look at it except when I am expecting a confirmation or access email. Periodically, I log on, select any messages, and delete them without reading them. There is usually very little.
I try to be pretty careful as well. On all of my other six email accounts, I probably get one spam message every month or two, usually someone from some foreign country wanting to share his untold wealth with me. Since I already have everything I could possibly desire in life, I haven't replied. :)
