tool carousel
tool carousel
Keith Tompkins
tool carousel
Keith Tompkins
>This is the prototype for tool carousels I'm making for the shop, made from baltic birch plywood with a white oak spindle, and revolve on a lazy susan fixture. The finished pieces will probably be made of walnut. The idea is the tools I need will be within easy reach, and cannot fall out or roll onto the floor while I'm turning.I'm working on a ratchet mechanism so the carousel doesn't rotate unless I want it to. Three such carousels will hold 36 tools in the space that currently holds 14 in my tool rack. They can be popped from their space in the rack, and installed on the lathe. This one will probably become my travelling demo model.
Re: tool carousel
Re: tool carousel
jwoodwright
>Keith, That is way better than my prototype! I wanted one to travel with as well as sit on the lathe bed. I like your idea better! John K.
Re: tool carousel
Keith Tompkins
Re: tool carousel
Keith Tompkins
>Thanks John, We pretty much had the same idea! Some don't like the idea of exposed tool edges protruding, but I apprenticed as a cabinet-maker right out of school....I cannot bear to place a cutting tool on its edge. (A rookie offense that could get you fired)I also wanted to be able to grab a tool handle, lift, and go right to turning with very little fuss.
Re: tool carousel
Re: tool carousel
jwoodwright
>Keith, I know what you mean! I took shop class seriously and worked around and with Carpenters until I was drafted. I still lay my planes on their side. In fact they're stored in a drawer, blades retracted, still on their sides!
The cutting edges are protected by that interlocking floor mat material. It's like 3/4" high density foam rubber. I had them up and was running out of Bandaids...
It all started with a cable reel. Found out it was ABS. Some 1 1/2" ABS pipe, MDF... My prototype has lasted longer than I thought.
I like your idea of it being tall and you lift them out. May save on the Bandaids... John K.
Re: tool carousel
Re: tool carousel
Peter Hyde
>Here's my version from '05. Baltic birch and slots instead of holes. The sloping arrangement keeps the tools in place but not for carrying around
Re: tool carousel
Jesper, Denmark
Re: A suggestion........
Jesper, Denmark
>I think the top disc with the holes in is too high up. If you lower it a bit, it will be easier to get the tools in and out fast. As it is, you will be fiddling around to get it out ind into the rack.
My fixed rack on the wall behind the lathe has the top plate with the holes in it about the level of the ferrule on the handles.
Just a suggestion...........
Re: tool carousel
Re: tool carousel
>I like yours better. I was going to suggest putting notches in so you don't have to "aim" for the holes. When I'm production turning I tend to grab the tools in a hurry. My problem is for different production jobs I use different tools so I would need about 3 or 4 different rotary designs. That's whey I use a flat table. I can lay any tool of any size down on it. I do have vertical storage for the tools when they aren't being used.
Re: tool carousel
Re: tool carousel
Cyril Griesbach
>Here is my version on a lazy susan bearing. Holds 26 tools.
Re: tool carousel
Keith Tompkins
Keith Tompkins
>Hi Jesper, I kinda like the higher level, other tools will fit as well, and it seems like it would be more trouble to get tools in and out if it were lower...I'll give it a try, thought. Thanks.
Re: tool carousel
Keith Tompkins
Re: tool carousel
Keith Tompkins
>Hi John, Good to see you in Richmond. I'm sorry I didn't get a chance to visit with you more. I enjoyed working in the vendor area, but too many people to talk to at the same time....I barely left the vendor area; my wife came along but wasn't feeling well so we spent evenings in the hotel room. BTW, Hope your demos went well.
I designed all of my tool-holding space so that nothing could fall off the wall or out of its rack while I was working..for example, my chucks slide over a turned rod, then a pin is inserted through a hole in the rod. Using holes instead of slots will hopefully help prevent picking up 12 scattered tools if the rack gets bumped...with my luck, it would happen right in the middle of a demo! My tools angle back, but not as much as Peter's, which I like. Next, I want to turn a top and bottom, and use a piece of sono-tube to make a carrying case...An idea I got from Steve Sherman. Just drop the whole unit in, tools and all, install a foam spacer, and install the lid.
I use a flat tray as well, but the space for tools is limited, and my lathe is far from the wall rack.
Re: tool carousel
Keith Tompkins
Re: tool carousel
Keith Tompkins
>Hi Cyril, I like the idea of not having to use a top rack...that solves the problem of long and short tools, and nothing falls out. Cool.
Re: tool carousel
Keith Tompkins
Re: tool carousel
Keith Tompkins
>Hi Peter, there must be hundreds of different racks out there....it would be a good contest to see who could design the best rotary tool rack! Yours looks like a good one.
Re: tool carousel
Screw attached where bevel exposes inner wall
david
Re: tool carousel
Re: Screw attached where bevel exposes inner wall
Don at Central Illinois
>Thanks. After going back and looking closer, I can see it now. Guess it's time to go back to the eye doctor and update my specs.
Re: tool carousel
Re: tool carousel
>I love the sonotube traveling storage idea. That's pretty cool.
Sorry I didn't get together with you at the symposium. Next time I'm going to say let's meet for dinner, here, at what time. That way I'll already have a date and won't get pulled away to other groups.
Re: tool carousel
Re: tool carousel
Mike Nelson
>Good idea Cyril, I'm not too concerned with tool holders but wouldn't that look good with large bamboo holders?
